Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Won't suck up the water
When I cleaned the carpet the water is not being suck up as I clean.
  • 1,673 Answers
Re: Won't suck up the water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid for the dirty water tank is not locked down all the way around.
Posted on Jan 10, 2008
  • 7 Answers
SOURCE: Kirby sentria
Hi There, The machine does not actually suck the suds up. Basically the machine lays the foam down which then crystalises and absorbs the dirt in the process. Once this has had around - 4-5 hours to dry then you vacuum up as normal taking the crystalised dirt away. You should really use the Genuine Kirby product as it's very good but you can also you any other DRY FOAM shampoo. Hope this helps Chris
Posted on Sep 23, 2007
  • 25 Answers
SOURCE: no suction
if this is a 9400 series check and make sure the red flap in the lid of the dirty water tank is not closed.
Posted on Apr 04, 2008
SOURCE: I have a Bissel proheat
I'm not sure if this will help but I had the same problem and was about ready to pull my hair out. I ended up taking the fill tank off and if you look inside where the red overflow flap is you will find a small screened opening. I found that mine was pretty clogged up with debris but once I removed the mess and put my machine back together it is now sucking like a champ. I hope this helps. Here's hoping that you don't have the pay for a service person to look at it.
Posted on Nov 04, 2008
  • 97 Answers
SOURCE: steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Posted on Aug 02, 2009
SOURCE: My Hoover SteamVac Agility's dirty water tank isn't filling up
Posted on Sep 29, 2009
Testimonial: "The return hose was split, but it would have been nice if the advice also explained how to check for the split in the return hose. Thanks though!"
SOURCE: Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Posted on Apr 13, 2010
0 characters
3 Points
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
The cleaner is not sucking up the water from the carpet
There should be a filter. If it's clogged or old, water will not flow through it properly. Meaning... Your machine will not suck the water up, once you've made a big mess on your carpet.
Good luck and Merry Christmas, Bill
Dec 19, 2014 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Why wont my bissell quicksteamer **** up the water?
Hey Kailyn, having no suction is a problem. Here's a quick link to troubleshooting steps to assist you.
Jan 12, 2013 | Bissell 1770 Quicksteamer II Upright...
I shampooed my carpet, loaded clean water twice and added the cleaning solution. Then it dawned on me, the carpet is wet and there is not dirty water return. What am I doing wrong?
Look for a place where the dirty water reservoir is not sealed. There is air being sucked in somewhere else instead of the bottom where it's supposed to **** the water.
Jul 20, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell proheat
Where the lip of the tank sits on the clear window, is the gasket there? If it is missing, it won't suck up the water. It is black, oblong (#24)and sits in a slot on the clear window providing a seal for the tank. Is the filter clean(#62), should be sitting in the square opening on the bottom of the lid, it sits right over the sucking opening.
Feb 25, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
450 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
