Question about Numark ttUSB Turntable
The plate on my numark tt USB is wobbiling
The plate on my numark TT USB turntable is wobbling.it doesn't effect just playing records but i cant scratch or mix because the wobbling shakes the plate and the needle jumps. is there any way to tighten it? please help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Numark Master
  • 924 Answers
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
Posted on Apr 27, 2015
SuperTech-11
  • 1591 Answers
SOURCE: how do i hook a numark tt 1625 turntable to a
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Posted on Feb 26, 2011
  • 104 Answers
SOURCE: I can't find a needle/cartridge for my turntable,
if you have the headshell left with the 4 little wires hanging out then you will need a complete cartridge.
turntableneedles dot com/Half-Inch-Standard-Mount_c_49632.html
if you have the cartridge part then it's still good and you only require a new needle. Type your cartridge number into the search window at the above website.
Posted on Apr 30, 2010
  • 6 Answers
SOURCE: When I scratch with my numark tt1625 its very slow to spin again
Try Changing The Slipmats Gemini Slipmats Are More Slippery Than Standard Numarks I Use ThudRumble Frosted Plates In Place Of My
Original SlipMats On My 1650's
Posted on Apr 11, 2010
  • 8404 Answers
SOURCE: no signal coming from rca output on numark pro
Please recheck all connections from the 'needle' to the end of your hook-up cable. Check with a continuity checker if you have one (volt/ohm meter will do nicely)
Posted on Mar 11, 2010
djproaudio
  • 515 Answers
SOURCE: pitch trouble numark tt-x1
Either the pitch control is damaged, or your drive system is damaged. Unfortunately for either case, your going to need some professional assistance.
Sorry I couldn't be of much more help.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
I cant get sound from my turntable. How do you hook it up?
As long as you can hear the record playing in the groove of a record, by ear, then the problem is that the connection to your computer is wrong. Since this is a USB turntable it will have to plug into a USB port. So you need to check that you have connected to the right type of USB port. That the port is working. See Control Panel on a Windows Machine. That the signal level from the port is set high enough and that it isn't switched off. You might also need to check the drivers for the device are installed and up-to-date.
Mar 28, 2015 | Numark ttUSB Turntable
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
How to plug up a Numark tt-1700
Like any other turntable - into a Phono preamp.
Web search "Numark TT 1700 manual". It's at numark.com.
Aug 12, 2011 | Numark TT1700 Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
What programs or software can i use for the numark tt-100 direct drive turntables?
you can use any type of software such as VDJ Traktor or Serato as long as you have timecoded vinyl and a external sound card like scratch live of the maya 44usb or native instruments 2 4 8 10 will work .
May 18, 2011 | Numark Audio Players & Recorders
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
I purchased a numark tt usb running under windows xp. i want it to run under windows 7 64 bits. what to do ?
The software works for both Windows 7 and Windows XP. You should just need to install it and follow the instructions. If you do not have it anymore, you can download the software and manuals at
http://www.numark.com/ttusb
Jan 17, 2011 | Numark ttUSB Turntable
Jan 19, 2010 | Numark BATTLE PAK v.4 Turntable
CAN'T HEAR MY RECORD PLAYING
my numark stop button won't work the plate won't play or nothing
Jan 08, 2010 | Technics SL-1200MK2 Turntable
Numark ttUSB Turntable Logo
313 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
