Question about Cameras
Which battery required on this camera - Cameras
    Master:
  • 456 Answers
What camera ? do you have an old one to take model number off ? or do you have the model number off the camera ? these will tell you which one you need
Posted on Apr 26, 2015
Hi friend, in these camera which type of battery is good i used panasonic battery but they will be finished in 3 or 4 hour so which battery is good for these camera vivitar vivicam 7024 f=5.1mm and f=...
The resourcefulness of the camera is what achieves the experience. Usually an already acquired camera least malfunctioning is within user experiences. The camera would require component devices mentionable as replaceable or delectable batteries. Also occasionally, the depleted resources may require restorations mentionable as power charging or discarding to acquire from alternate location to recapture feature functions. The cameras details are acquirable from owner's user guide or observing devices feature functions to ascertain what is comprised. Power batteries for the camera comprise of several capacities. Prior to requesting from retail, ascertain the most compatible battery required by device either from owners use guide, or inspecting the battery compartment for written details as brands, cell capacities. Also, camera batteries may provide suitable power supply capable of several brands. Usually advisable to acquire the brand most prescribed suitable for the camera. Significant notes includes acquiring batteries that make the camera achieve as much productivity. Unless those Panasonic batteries were the prescribed version for the device, it may be most suitable as high capacity currency supply. Several batteries perform similar functions of capacity requirements also available in feature compatibilities for camera. Mentionable examples are Duracell, energizer and ever ready brands. Camera devices are general making possible several means to resort. For example, a camera may least malfunction but require acquisition of new devices to attain feature effects least available on the old device. Prior to visiting the electronic retail either on the networks or at store locations, inspect the device to make possible acquire another device in place that would have feature functions least present. Camera inspection observations include innovations of motion pictures, user friendly features, multifunction features, also technical features includes pixel quality, adjustable lenses, only mentionable with innovated cameras.
Feb 07, 2011 | Cameras
When I put my battery back into my camera after charging it. The camera will still not turn on. Why ?
Check the position of the batteries. Some camera require the batteries to put in (+)(+) positive-positive position if we see from above. Some other require the batteries to put in (+)(-) or (-)(+) or (-)(-).
Make sure you have put in the batteries in the right place.
Sometimes, unchargeable batteries will stay longer than chargeable batteries, You can try to insert that kind of batteries.
If useful, RATE please.
Jan 18, 2011 | Casio Exilim EX-Z77 Digital Camera
Where to put 3 AA batteries
The Disney Micro only requires ONE AA battery. The battery slot is locate at the bottom of the camera. To open the compartment, simply slide it to the open.
The Disney Camera also comes in the Disney Max, and this model requires TWO AA batteries.
Hope this helps,
Andrew Don't forget to vote.
Apr 12, 2010 | Disney Pix Micro Digital Camera
Camera has lens error
If you've recently dropped the camera you may have lens damage that will require professional repair. If the camera hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 29, 2009 | Casio Exilim EX-Z77 Digital Camera
Have a canon IXY with a lens retracting issue, also does not focus. states to restart camera.
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either problem will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 15, 2009 | Canon Cameras
Camera lens stuck and wont go back in
If you've recently dropped the camera you've likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 15, 2009 | HP Cameras
Lens will not retract
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either problem requires professional repair. If the camera hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Canon PowerShot S2 IS Digital Camera
It won't stay on and the lens seems jammed in the collapsed position.
If you've recently dropped the camera you may have damaged the lend tube (housing) or jarred the zoom mechanism off of its track. Either will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 06, 2009 | Konica Minolta DiMAGE E500 Digital Camera
Camera wont turn on. Says lens error and restar camera
If the camera has recently been dropped you may have lens damage that will require professional repair. If it has not been dropped, your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 19, 2009 | Canon PowerShot S3 IS Digital Camera
Put new batteries in and it keeps powering down saying to change the batteries
Problem also could be with the type of batteries you're using. I purchased batteries at the dollar tree once and had that problem. When I purchase duracell batteries I don't have the issue. High drain devices like digital cameras require better batteries and cheap batteries like the ones from discount stores don't have the output required.
Oct 14, 2009 | Canon PowerShot A410 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
