Keeps coming up with H20 what does this mean - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Water
Posted on Apr 29, 2015
Hi my machine keeps fashing H20 what oes it mean?
H20 means "Check tap and pressure of incoming water"
Basically, it thinks that you have turned off the water supply or that the water supply pressure is too low.
Jul 12, 2011 | Hotpoint Aquarius WF000 Front Load Washer
It keeps coming up h20 on lcd screen
(Quote)
Error code H20
If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.
If your machine IS in demo mode come back to me and I will tell you how to get back to normal mode - it's too long to put in this solution ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 25, 2011 | Hotpoint Ultima WF865 Front Load Washer
My Hotpoint ultima washing machine wt761 keeps filling up displays H20 need help Thanx
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. H20 normally means not filling but sounds like the switch is faulty. Hope this helps
Mar 02, 2011 | Washing Machines
Problem with it saying about shutting door then displaying h20
i assume the model is a wma74 or something like that?
H20 means it not getting water.
first check your hoses for kinks. then turn off the water, disconnect inlet hose, get a basin and turn water on to make sure water getting that far. if so check that the inlet filter is not blocked with sediment. (where you screwed hose off from) if so using a pair of pliars pull out filter and clean
all of above ok its more than likely a double solinoid valve you need.
easily fitted by removing the lid and all will come clear ( two hoses, two wiring blocks) just keep note which goes where.
hope this helps
Jan 05, 2011 | Hotpoint Washing Machines
The DVD player doesn't work. The service code HO2
I keep having h20 come up on my dvd play er what does that mean it want play
Jun 04, 2010 | Panasonic sa-ht800V Home Theater Audio...
H20 is showing on my display on my indesit
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Mar 13, 2010 | Indesit Washing Machines
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
