Question about LG WT4801CW Top Load Washers
My LG washing machine top is locked and the washer is broken, is there an emergency release button to open the door?
    New Friend:
  • 3 Answers
You have to lift the ENTIRE top just enough to look on the right side towards the middle and there is a little red piece you pull to release it. There is a youtube video out there showing it but I can't remember where I saw it. I hope that helps!
Posted on Apr 27, 2015
SOURCE: LG 1480fhd
In my case this problem was caused by a broken handle in the door assembly. I agree with dovi that you can release the catch from inside the machine if you remove the soap dispenser unit. You can then remove the door and disassemble it to see if the plastic trigger is broken.
If the door handle is broken you cannot exert any force on the metal catch - you think you are triggering the mechanism but you are not.
Posted on Nov 17, 2007
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: lg wd-8013c washer door latch broken. Is there an
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
Posted on Jan 21, 2010
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
How can I unlock door of front loading LG washing machine
You can try "resetting" the washer. Unplug or trip circuit breaker. Push and hold power button for 10 seconds. Plug back in. Power on and back off. See if that works. If not, try pushing the door in pretty hard and see if tha releases the lock. If all else fails, you can take the top off, the control panel off and reach down with a long screw driver and manually release the lock. Good luck.
Dec 12, 2017 | LG Washing Machines
Tip
Manual Door Unlocking of Maytag Neptune Front Load Washers
Maytag Neptune Front-Load Washers are equipped with emergency access cord that can be used to unlock the door when the door lock mechanism fails to unlock it after a wash load is done. The emergency access cord is located under the top cover and can be accessed through the dispenser bezel. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off to access the emergency access cord. Carefully pull the emergency access cord steadily then open the washer door.
The pulling of the emergency access cord overrides the wax motor and the sliding gear is pulled from right to left away from engagement with the rotating gear. It allows the rotating gear to release the wire loop of the door.
The failure of the door lock mechanism to unlock the door is due to a failed wax motor in the extended position. This requires the wax motor to be replaced. Access to the door lock mechanism for the wax motor replacement requires the removal of the front panel and lifting the top cover. Click here for the detailed front panel and top cover removal procedure.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Door will not open. Have tried emergency lock release on p. 29. Still does not open. Have unplugged for 1 hr. Does not open.
emergency lock as in the release mechanism inside the access door on the lower right corner of the face of the washer? try pushing in on the door with force will doing this
Jan 20, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
The door button has broken. Is there a way of opening the door
Remove top cover of washer,and see if you can release it from inside the washer, you may have to force the door lock open, so be prepared for the fact that you may damage the door lock as a result of forcing the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Candy Washing Machines
Lg wd-8013c washer door latch broken. Is there an emergency release?
Sep 14, 2009 | LG Washing Machines
Door jammed with a load inside and no power to the
Door lock mechanism is probably broken. Also circuit board in powerhead most likely has blown resister R-11.
To get the door open in an emergency, remove the plastic dish on the top of the washer. It should be held in by four screws. underneath you should find a plastic cord that can be pull to release the latch manually and open the door.
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
LG WT4801CW Top Load Washers Logo
130 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
