Question about Hotpoint WML520 Washing Machine
Machine doesnt complete some of its programs and all the lights start flashing
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Check pump for blockage
Posted on Apr 27, 2015
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
The machine drains and starts but then beeps continually and the programe light flashes fast. It doesnt matter what programe it does the same
Hi, if you could add the make and model of your washer to the above text and then repost the query we might be more able to help.
Even without this knowledge it seems to be a controller issue.
please add the details and repost the query.
Sep 17, 2015 | Dishwashers
It doesnt complete some cycles and all the lights start flashing
I recommend you review your Owner's manual trouble shooting section. No manual? Try manualslib.com
Apr 26, 2015 | Hotpoint WML520 Washing Machine
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
WFL 1200 stop during wasking and diod is flashing
Sounds like the machine is not draining all the water or doing it too slowly, check the pump filter (if it has one) for coins, debris etc. Check that the outlet pipe is clear particularly if it is connected directly to the plumbing under the sink, remove the grey washing machine hose from the spigot on the plumbing and check both bits for obstructions. That machine also has a 'container' which is located at the top left (when looking at the back of the machine) this is between in inner and outer sections of the grey corrugated drain hose, this container could also be block. If the machine starts to flash before the rinses then there is also a possibility that the heater is faulty. You can test this by putting the machine on a cold cycle and seeing if it completes without a problem.Let me know if you need any further assistance
Nov 27, 2011 | Bosch Washing Machines
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Hotpoint WML520 Washing Machine Logo
91 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
