Question about Hotpoint WML520 Washing Machine
It doesnt complete some cycles and all the lights start flashing
  • tom cassidy
    tom cassidy May 04, 2015
    Hi peter russell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Hotpoint Master
  • 2,992 Answers
I recommend you review your Owner's manual trouble shooting section. No manual? Try manualslib.com
Posted on May 04, 2015
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Hey everyone. I have a '95 Dodge Ram 1500, 5.2, Manual trans. I've been a mechanic for 27 years and a member of Fixya for a couple. I've been over this darn truck from top to bottom and cannot find the...
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the engine light. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.Dodge trucks have a diagnostic trouble code retrieval method, Unlike Gm and Ford trucks the Dodge line of trucks has no data port connector to gather codes from.Instead Dodge has a ignition cycle activation sequence that anyone can active by turning the ignition key on off in rapid succession five times with the cycle ending in the "on" position.
Once this activation has started the check engine light will start to flash. The first set of check engine light flashes will be the first digit of the two number code. After the check engine light pauses for a short time it will start to blink again starting the second digit identification and completing the code's second number. If additional trouble codes are stored in the computer the first digit will begin to flash, and then the second digit. For example: the check engine light flashes four times, pauses and then flashes three more times the code is 43
Apr 24, 2011 | Dodge Ram 1500 Cars & Trucks
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WML520 Washing Machine Logo
110 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
