Question about Refrigerators
Panel saying F1. is that the same as FF. Very unhappy that a 17 month old refrig. is having this kind of problem.
  • Refrigerators Master
  • 5,323 Answers
Do u mean er 1f?
Posted on May 17, 2015
Testimonial: "I followed the advice I read. Turned off the icemaker. Dried everything out and let it sit for 4-5 days. That worked and if it does it again, I will repeat. Thanks"
  • Jorge Rendon
    Jorge Rendon May 17, 2015
    With these units using adaptive defrosting technology..... they are becoming extremely hard to troubleshoot as well as costly to repair. The govt. is mandating more energy efficient products. So you save money on energy and spend it on repairs.
    It sounds like your unit is building up frost. You partially confirmed it when you said you un-plugged it and there was water all over the floor.
    In the following parts pictorial....part # 407A is the ice fan motor. It appears to be located in the bottom of the unit. I would check for voltage and fan operation at that point.
2 Suggested Answers
  • 1218 Answers
SOURCE: Refrig will not syay cold Only 6 months old
Good day,
Not your problem. The machine carries a full one year warranty on all parts.
Call Sears for a warranty service call.
Posted on Feb 05, 2010
Refrig making noiise
Ask them cover deforst heater
Aug 09, 2017 | Samsung Refrigerators
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
Good day,
Feb 05, 2010 | Kenmore Refrigerators
HELP!!__CALLING ANY GE FACTORY TECHS
You say " all thermistors check fine " , how did you check them ? Did you check for the 5-8 DC volts at the main control board , for the thermistors ? Did you do the diagnostic check for the thermistors from the control panel ? I'm sure you know there are 5 thermistors , since the refrig has the dual evap . Possibly the # 5 is bad , since it is the freezer temp " controller " , yet if it tells the board it's not cold enough , it still sends refrigerant to the refrig evap . Since the refrig evap has 2 fan motors , can't remember if there is a damper there also . Maybe when the # 3 thermistor is satisfied , it only cuts the fans off , even though refrigerant is still going thru the refrig evap .
Oct 31, 2009 | GE Profile PSH23PGT Side by Side...
17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
May 23, 2009 | Vizio VX42L 42 in. LCD TV
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
Refrig not working
what brand is this?? Model#? Is the freezer fan working?? Is the compresor running?? Is there any frost on the back panel in the freezer??
Dec 25, 2007 | Ovens
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
