Question about HSM Classic 386.2 High Performance Paper Shredder - Cross Cut 16 Per
I shredded an envelop with a key in it
A piece of the key is stuck inside the shredder. How do I get it out?
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: If I feed in a single piece of paper it goes
I think that the shredder blade is already faulty or not sharp anymore, Or try to locate the motor gear and put some grease or oil.
Posted on Jul 15, 2011
Damaged shredding teeth on roller
I don't believe the parts cost, if available would be less than a new shredder if this is a home office model. Look on craigslist, Ebay or whatever for a new one. My advice, get one that can take at least 8 - 12 sheats and cross cuts. * is basically an envelope with 3 trifold pieces. Not very much unless you open all your personalized junk mail.
Sep 13, 2013 | Office Depot Ativa X1800 Shredder
GBC #SC32 auto stop not functioning
take the shredding portion of the shredder off and check in its teeth (while unplugged of course) to check that there are no errant pieces of paper or plastic in the device. You may even want to try and blow out any possible paper stuck inside with some canned air or something.
Sep 06, 2011 | Quartet gbc Office Equipment & Supplies
After shredding a piece of paper the machine wont shut off it keeps running
Please check to make sure the paper sensor is not blocked in some way.
This usually happens if there is any sticky tape on the paper or envelope shredded.
Apr 01, 2011 | Staples Office Equipment & Supplies
Shredder will go into reverse but not forward
If this is like my elecrtical paper shredder the solution is to unplug so it cannot shred you and then take any squashed up pieces of paper out of the cutters on the inside of the machine. I have to unblock my machine after every 50 or so pieces of paper I shred.
Feb 07, 2011 | Vacuums
MY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH PAPER.WENT TH SHRED ENVELOPES AND TOO MUCH PAPER WAS INSIDE.hOW DO I UNJAM THIS? iVE TRIED REVERSE SLOWLY THEN FORWARD,ETC.IT IS STUCK BADLY.I SAW AN ANSWER...
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Apr 21, 2010 | Fellowes OD1200 Shredder
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
Shredder Jams with more than 1 piece of paper thickness
I have seen paper shreds build up inside the cutter housing on this model. It grows into a big tumor inside and places a lot of resistance. You will have to take it apart and clean it thoroughly. Also, oiling the cutter asm.
Aug 31, 2009 | Fellowes PS70-2CD Shredder
Won't turn off
The optical switch may be clogged. UNPLUG the machine and remove all shreddings from under the cutters. Look down from the top and in the middle to be sure that there is nothing blocking the "electric eye" located there. Shredding labels or self stick envelopes can leave pieces stuck to the eye.
Jul 07, 2009 | Office Depot Ativa DQ60M Shredder
Broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
May 03, 2009 | Fellowes 3011001 Shredder
HSM Classic 386.2 High Performance Paper Shredder - Cross Cut 16 Per Logo
95 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
