Question about Wine Enthusiast 18 Bottle Dual Temp Wine Refrigerator - Sharper Image -
The fridge is making a loud humming noise. Is it the fan that needs to be replaced?
Loud humming noise coming from fridge
sounds like the evap fan is hitting something.. or is loose and making noise... I would remove the cover in front of the fan and take motor out and reinstall it making sure all washers and grommets are in place...but I would look for ice build up first, this could indicate a defrost problem..... hope this helped ken
Sep 29, 2014 | Bosch Refrigerators
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Freezer fan makes loud humming sound
sounds like the bearing in the fan motor is gone. need to replace it.. ok
Feb 12, 2011 | Hotpoint HSS25GFP Side by Side...
My display refrigerator in my shop is making a loud humming noise. it still runds fine but is really loud.
First check both the inside freezer fan and then the condenser fan
(underneath in back) for obstructions or paper
Determine exactly where the noise is and if it coming from
the compressor then you may need a ser tech or replace the fridge.
These are the only three components that CAN make noise.
other than maybe an icemaker.
Good Luck!
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 25, 2010 | Heating & Cooling
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Wine Enthusiast 18 Bottle Dual Temp Wine Refrigerator - Sharper Image - Logo
326 people viewed this question
Top Wine Enthusiast Computers & Internet Experts
David Payne
David Payne
Are you a Wine Enthusiast Computer and Internet Expert? Answer questions, earn points and help others
