Question about Refrigerators
How do I get the back of the unit to get to the drip tray
  • Refrigerators Master
  • 5,323 Answers
SOMETIMES ITS COVERED BY A CARDBOARD WHICH NEEDS TO BE UNSCREWED BUT IT SHOULD BE VISABLE FROM THE BACK EASILY
How do I get the back of the unit to get to the dr - get-back-unit-get-drip-tray-4f0hlddt4gbryw0z5z50jz3f-5-0.jpg
Posted on May 09, 2015
Where is the serial number on delonghi magnifica S ECAM22.110?
I looked at a video on the Keurig Customer site. The serial number on my unit which is a K10 is the bar code number located on the bottom of the unit. I removed the drip tray and turned the unit upside down. On other units it may be on the back wall of the drip tray housing. You have the remove the drip tray and shine a light into the slot. Once again it is the black/white barcode label with a number. I don't know where it is on your unit but it is somewhere and should also be the barcode label. Hope this helps.
May 18, 2014 | Keurig B70 Coffee Maker
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
The dregs drawer missing indicator on, unit won't work.
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco 21103 unit and it keeps getting an error message of ''dregdraw Miss'' what is that?
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Oct 27, 2009 | Coffee Makers & Espresso Machines
Drip Drawer will not release
The tray appears to have been inserted just slightly askew, causing the notch in the back of the tray to get hooked under that black bit. I was finally able to remove it by tilting the front upward and pulling out. I have reinserted the tray several times since and it pulled out as simply and smoothly as it usually does.
Feb 18, 2009 | Saeco Royal Digital Plus Coffee...
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
