Question about 2011 Ford Ranger - SuperCab - 2500 Series Base Rack System
My 2010 ford ranger 2.5's injector pump is not deliver fuel to the injectors, what could be the problem?
    Master:
  • 987 Answers
Check fuel filter and lines for kinks
Posted on Oct 08, 2015
2.5 ranger td 2007 diesel pump timing marks n will da key way on the pump should b same as the timing marks
images for 2.5 ranger td 2007 diesel pump timing marks
Ford ranger 2.5 diesel pump timing marks - Fixya
www.fixya.com/.../t12609400-ford_ranger_2_5_diesel_pump_timing_...
Apr 29, 2012 - SOURCE: need the timing marks for a 3.1 td 5 cyl diesel injectionpump. isusu engine?? have you looked for a 8mm hole in timing gear that ...
Mazda Bravo 2.5 TD 2000 - YouTube
? 10:00
https://www.youtube.com/watch?v=D8zJeouIXfo
Sep 11, 2010 - Uploaded by V8Jagnut
and one other , would a miss timing on the fuel pump cause engine .... The only thing I've ever seen with a Mazda dieselengine was an old Mercury Lynx. ... Ford Ranger Mazda B25002.5TD Servicing Guide Part 2 - Air and .
Oct 29, 2015 | 2006 Ford Ranger
1988 Ford Ranger 2.9L A/T, 2wd, A/C. Won't Start. Fuel pump does not come on. Scan tool cannot connect to the ECM. Verified Fuel pump Relay good. Ground to STO Fuel pump pin will engage the fuel...
The engine computer must be working to get spark and fuel injector pulse. I would want to know if the computer has power and is functional. The computer grounds the EEC relay and the fuel pump relay as well as the injectors.
Aug 26, 2013 | 1988 Ford Ranger
1988 ford Ranger will not stay running unless pour fuel down intake
dumb question but did you prime the injector pump and bled the injectors?
Apr 11, 2013 | 1987 Ford Ranger
Code p0171 on 98 ford ranger
Well code 171 means the O2 sensor is telling the computer the fuel mixture is too lean and the computer can not make it go rich by increasing on time for the injectors.
The problem could be the O2 sensor, or low fuel pressure, or several other factors.
Feb 21, 2013 | 1998 Ford Ranger SuperCab
Where do locate the rpm meter on the ford ranger 2010 engine
I believe the rev unit is on the injector pump and part of the wiring that you may have not connected or you have a different model pump
Dec 10, 2012 | 2010 Ford Ranger 2.3
HOW TO FIX CODES 171 AND 174
fault code p0171 is system too lean bank 1.................. intake/exhaust leak. air system MAF/VAF sensor. Fuel pressure/pump , injectors HOS2.
fault code p0174 is system too lean bank 2...................intake exhaust leak, fuel pressure/pump , injector(s) Air system, Hose connectors
hope this helps you
Jan 07, 2012 | 1999 Ford Ranger SuperCab
Ran out of fuel trying to getting engine started
Well if you ran out of fuel that means the pump sucked lot of air in, and it wil take o while for the pump to deliver the fuel back again to the injectors. and if its a diesle, you might need to purge it.
Dec 05, 2010 | 2010 Ford Transit Connect
1999 mazda 626 6cyl no fuel geting to onjectors
Priority Action Part Type Cause
1 Inspect Fuel Pump fuse - short to ground in fuel pump circuit
2 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
3 Inspect Relay - Fuel Pump Faulty Fuel Pump Relay.
4 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
5 Inspect Fuel Pump Low Fuel Pressure.
6 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC.
7 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat.
8 Inspect Fuel Rail - leaky Fuel Rail
From April 2010? What did the problem turn out to be?
Apr 25, 2010 | 1999 Mazda 626
Cylinders filling with gas
No it cannot. Most likely ur vehcile is EFI (Electronic Fuel Injection), which means that current must be floweing for the injectors and the fuel pump to be working. The pump allows the flow of fuel.
Mar 13, 2009 | 1987 Ford Ranger
Fuel Problem
fuel pressure regulator? This diverts excess pressure from the rail back to the tank. When they wear out they usually stay stuck open thus diverting all pressure back to the tank. Pressure tests do not reveal this as pressure is checked before the rail not in it. I do believe you have a bad fuel regulator. They are 75US ouch.
Dec 06, 2008 | 1988 Ford Ranger
2011 Ford Ranger - SuperCab - 2500 Series Base Rack System Logo
77 people viewed this question
Top Rhino-Rack Vehicle Parts & Accessories Experts
Shaun Thompson
Shaun Thompson
Bill Boyd
Jerry Ross
Jerry Ross
Are you a Rhino-Rack Vehicle Part and Accessory Expert? Answer questions, earn points and help others
