Question about Blomberg Dishwashers
I have a blomberg dwt 55500 ss dishwasher motor just keeps running and board time doesn't count down. Any ideas?
techman
  • 3130 Answers
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Posted on Apr 14, 2006
  • 641 Answers
SOURCE: shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Aug 02, 2007
  • 213 Answers
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
SOURCE: dishwasher runs through the cycle but doesn't stop
most likely a new controller switch only...
Posted on Mar 05, 2008
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
Acces to manuals for Blomberg diswasher DWT23100SWD606BA
Blomberg lists the DWT 23100 SS here: http://www.blombergappliances.us/tall-tub-dwt-23100-ss.html . The user manual and installation guide are on that site. The direct link to the manual is http://download.blomberginternational.com/Download.UsageManualsBlomberg/US/en_US_201507011043783_User%20Manual%20-%20FileengUSA.pdf . Since the manual covers several models it should cover your machine. The installation guide is here: http://download.blomberginternational.com/Download.UsageManualsBlomberg/US/en_US_201507011043783_User%20Manual%20-%20FileengUSA.pdf .
Some other Blomberg appliance manuals are available here: http://www.blombergappliances.us/manuals-litterature/ . If you enter DWT 23100, three appliances are listed. None of these add SW to the model number. There are also B and W model.
I hope this helps.
Jun 22, 2016 | Cars & Trucks
Dishwasher is powered on but and making normal start up noise but no water is entering the dishwasher and not beginning the wash cycle
My Dishwasher is a Blomberg DWT 25200 SSWS. It had the same problem. It powers up but no water enters in it and the clock didn't advance. This is what I did to fix it.
You can display the error code by powering off the dishwasher then pressing the 'Program' and 'Half Load' buttons at the same time then power on the dishwasher. This will show an error on the screen. My error was E:1.
The problem was a disconnected blue hose at the bottom of it.
This is the overflow detector.
This little board has a 12 Volt relay that activates the main water valve which is a 120 VAC valve. There was nothing wrong with it.
This plate is at the bottom of the dishwasher to hold the water that spills.
May 07, 2015 | Blomberg Dishwashers
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Fills up but doesn't run time just counts down
A lot of times problems with that style GE washer can be resolved by resetting the motor control board. This tip i wrote explains how to reset that control board.
http://www.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Sep 16, 2011 | GE WPRE8150WH Top Load Washer
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
I bought a blomberg DWT36240 back in Feb 27 2009. no problems till now. When I put the washer on it just hums with no water cycling through. It will run till i manually shut it down I have cleaned the...
I have the same model, they recalled the pump. Get ahold of where you bought it and see if you can get their repair companies contact info. Blomberg is next to impossible to contact in Canada, not sure about the US.
Nov 15, 2010 | Dishwashers
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Dishwashers Logo
180 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
