Question about Homelite Garden
How do i drain the fuel tank on a Homelite 2400
Already changed the spark plug
    Top Expert:
  • Homelite Master
  • 43,059 Answers
Take cap off and turn it upside down. or use a siphon
Posted on Nov 30, 2015
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
I have a old homelite that won't start new plug fresh gas no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
Mar 11, 2014 | Homelite Garden
Homelite 4620 won't start
Back to basics, fresh fuel in the tank, replace the fuel filter in the tank, does it have a spark, try a new plug.
Nov 25, 2012 | Garden
Starts dificult; runs for 30 sec then shuts off abruptly
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
Jan 30, 2010 | Homelite Garden
Starter rope hard to pull
Usually these motors get tough to pull through when there's moisture (water) somewhere in the fuel system.
Fuel compresses, but water won't and when you pull a bit of water in the cylinder it will buck back on you.
Best bet is to drain the carb, fuel lines, and tank and put all fresh fuel/oil in. you can also pull the spark plug and pull the motor through with the plug out to dry the cylinder...
Oct 31, 2009 | Homelite 'Yard Broom' Leaf Blower
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite String Trimmer not firing.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Homelite Garden
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
1999 suzuki 800 maurader misfiring
did this just start all of a sudden or after being stored for a while? if it was stored then try new fuel, check and change fuel filter, and get some fuel system cleaner that goes in the gas tank, run til hot then let stand overnight. and try, old gas can gum up carbs starving the enging of fuel.
Apr 02, 2009 | 1999 Suzuki VZ 800 Marauder
HARD STATING CHINSAW ZR10926
try:
- Control fuel level, min. 25% tank capacity. and off course use correct ratio of fuel/oil
- Check air filter is clean.
- Remove spark plug,dry it, clean it and adjust it, and replace it, if necessary.
Jan 24, 2009 | Homelite Garden
Garden Logo
180 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
