Question about Philips Azur Gc4870/02 Steam Iron, 2600 Watt, Brown/Gold
Just used the iron 3 months after that it just flashes twice but does not heat up please help fix it
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
When I plug in my iron the light comes on but when I go to push the button to turn it on it does nothing, not even heat up. The iron is only 3 months old
Good Day!
Please open the cover of your iron and look for the thermal fuse inside.That is the only problem of your iron replaced it on the same ampere and temperature.
Thank you and don't forget to rate my answer.
May 10, 2011 | Irons
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Iron no longer has steam function
If you are using tap water then the hardness of the water could cause the problem. You can usually fix this buy running vinegar water through the iron once or twice like you would a coffee pot.
If you have been using distilled water then you probably need to replace the iron.
Jun 25, 2008 | Sunbeam Classic 3964 Iron with Auto...
Tefal turbo ro 400 iron
heatman101
Oct 08, 2007 | Tefal Ultraglide 1549 Iron
Philips Azur Gc4870/02 Steam Iron, 2600 Watt, Brown/Gold Logo
119 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
