Why does the printer say improper shut down and to avoid damage use on button for proper shutdown?
5 Suggested Answers
Enday
  • 3 Answers
SOURCE: Error Press OK! to continue
Hello johnny22, this is Enday inorder to solve your problem ..try this steps....uninstall your printer and then re-install the software again.... just see if its work...
If not just reply me inorder to give you another solution....
Posted on Jan 30, 2008
SOURCE: When I turn on my printer I get the message Error Press OK
You have to refit the micropump gear, this is happening because this gear should be out of its place. It's on the left side of your printer. I.ve just solved the same problem.
Posted on Nov 27, 2008
SOURCE: printer will not start
This is likely a hardware problem. However you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord. If this this does not clear the error you probably have a hardware issue. On my printer, after going through a diagnostic procedure with the HP Chat Tech and concluding a hardware issue I did a bit more research and then took the printer apart. It turns out that a fairly common problem is for the large white gear on the left side of the printer that drives the ink pump comes off the shaft. I reassembled it to the shaft and put the printer back together. When I plugged in the power cord the printer started and did about a 5 minute maintenance procedure and now works fine.
Posted on Jan 29, 2009
anujbhatt
  • 66 Answers
SOURCE: Error Message is
Reset the printer by following steps
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 10, 2010
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
Error Message is "Improper Shutdown" It says something like "To avoid damage, use the On button to shut down the device. Do not use the power strip or wall plug to turn off device. Can't get the machine to...
Apr 10, 2010 | HP Photosmart C6100 All-In-One Printer
I have owned a PS3 for 4 years now. I have had no real problems with the system itself. Today, 3/18/10, I was playing NCAA March Madness. The system shutdown in the middle of the game! There was no power...
It sounds like the power supply might be damaged.
Return it to Sony. If it is still under warranty, the repair will be free; otherwise, Sony will charge a flat $150 fee.
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Dec 12, 2009 | Dell Inspiron 1525 Notebook
"Improper Shutdown" - Printer keeps turning on and off.
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Sep 12, 2009 | HP Photosmart C6100 All-In-One Printer
Printer cycles on/off and displays "improper shut down"
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Printer cycles on and off continuously
make sure that the switch is properly pressed on and it pops out again.
Jul 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will not start
Nov 24, 2008 | HP Photosmart 3210 Printer
Jan 30, 2008 | HP Photosmart 3310 Printer
k24674
jasbo
jasbo
