Question about Whirlpool Washing Machines
Whirlpool super capacity plus washing machine how do I clean the filters
  • 1028 Answers
SOURCE: Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Posted on Aug 07, 2008
SOURCE: can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Posted on Nov 01, 2008
SOURCE: washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
Posted on May 14, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II, Quiet Wash, Super
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Posted on Aug 13, 2009
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    Is there a filter on a whirlpool heavyduty super capacity plus 7 cycle 2 speed washmachine
    for top loaders pull up the center section of the agitator and the filter is right at the bottom of that
    for front loaders ,consult you user manual
    May 11, 2016 | Whirlpool Washing Machines
    Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
    Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
    Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
    WHat is the capacity of the Whirlpool LLR9245BQ1 top load washer?
    Hello there
    • Washer Type: Washer
    • Load Type: Top Load
    • Volume Capacity: 3.2 cu/ ft
    is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
    Jan 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    I have resently purchased a second hand super capacity machine, not yet run it. The softner receptor is very dirty and I was wondering how to clean it out. I have taken the top bit off but am unable to...
    You can use vinegar to clean the machine take 100ml of vinegar and two buckets of hot water till the plastic tolerance then start the normal program the hole machine inner unit will be cleaned you can use the same process two months once the cloth cleaning quality will be good
    May 17, 2010 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
    Whirlpool Super Capacity Plus washer drum removal
    What kind of residue? Grease? Sometimes a buildup of fabric softener will look like grease. If so, removing the agitator and inspecting it will show a buildup of fabric softener on underside. Rinse with hot water to remove. If you need to remove the inner drum, you will need a special tool for that. Try a local appliance parts business. They might loan or rent one, or sell you one. No filter to clean though. Grease should not be present as there is only the shaft of the transmission coming through a seal into the outer tub. Not likely to have grease migrate into tub. Fabric softener will be present on outer tub as well. Remove with hot water and plastic dish scrubber. Rinse and re-assemble washer.
    Aug 01, 2009 | Whirlpool Washing Machines
    Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
    Nov 01, 2008 | Washing Machines
    WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
    On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
    Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Agitator
    if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
    Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    37 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
