Question about ACDelco 2133859 Throttle Position Sensor TPS 19143600
Replaced the throttle position sensor body and now have a high idle
Replaced Throttle body throttle position sensors
There is another sensor mounted to the gas pedal. It has to communicate with the throttle body assembly. If the correlation is not correct between the two, the problem will persist. The throttle body assembly is usually the most common of the two, however the accelerator position sensor still gives problems.
May 11, 2015 | 2004 Nissan Quest
Surging idle
Bad throttle position sensor.
Nov 24, 2013 | GMC Yukon Cars & Trucks
High idle shifts hard but idle will go back down but shifts hard
You'd probably have to take it in to get it diagnosed, but I'm going to guess that it's the electronic throttle body.
The throttle body and throttle position sensor are in the same unit and if one goes bad, you have to replaced the whole thing.
This will cause high idle, stalling, hard shifts and irratic throttle.
Oct 20, 2013 | 2003 Chevrolet TrailBlazer
Have 03 Chrysler Sebring 2.4 Lx with a very high idle. (Undriveable ) replaced the map and throttle position sensor. That didn't work. Any ideas?
your throttle body door is stuck open check the cable from the gas pedel to the throttle body. if anything just to both cables off the throttle body andrun it. if it is the same with cables off when your idle air control valve is bad
Dec 05, 2012 | Cars & Trucks
Toyota high idle after new throttle body 2.4l
No, a idle sensor is an electrically-operated valve which allows air to bypass the throttle plate in a fuel injected engine to regulate idle speed. The throttle body sensor is used to monitor the position of throttle in internal combustion engine.---------------------------------------------------------------------------
Car Key Programmers
Nov 23, 2012 | Cars & Trucks
High idle after new throttle body
godiag key programmer
95 taurus idling too high like it is stuck wide open
Several issues can cause this problem, either singularly or in combination.. Check the throttle body for dirt and sticky carbon deposits. clean the throttle body using a spray can carburettor/choke cleaner, and with the throttle valve held open, wipe out the bore of the throttle body with a solvent soaked clean rag. Make sure the throttle valve is not sticking any where in the throttle travel between closed and open.
Next, check the idle air bypass valve that is mounted on the top of the throttle body, for dirt and carbon deposits inside that can cause the idle air bypass valve to stick in an open position. Clean the inside of the idle air bypass valve with carb cleaner.
If the ignition timing is over advanced, (Specifies timing advanced is10 degrees Before Top Dead Center, with the in-line spark out plug removed from the spout connector housing, and with the idle speed set to the idle RPM shown on the emissions sticker under the hood, with the engine fully warmed up,) use a timing light to check and set the ignition timing to specification.
The throttle position sensor must be installed on the throttle body using the required method or the idle speed will likely be excessively high. Beginning with the battery negative cable disconnected from the battery, and with the throttle position sensor removed, place the sensor in position on the throttle body with the drive tabs on the sensor placed after the drive tabs on the throttle shaft, the holding the sensor on the throttle body, rotate the sensor counter clockwise to align the mounting screw holes in the sensor and the throttle body, Insert the sensor screws into the senor screw holes, into the threaded holes in the throttle body and tighten finger tight. Carefully center the sensor on the sensor screws, then tighten the screws firmly without over tightening. Reconnect the sensor electrical harness connector.
Inspect the throttle valve idle stop screw adjustment that holds the throttle valve open slightly, to prevent the throttle valve from touching the throttle body bore surface with the throttle closed, and the accelerator pedal unpressed.
Dec 30, 2010 | 1995 Ford Taurus
High idle on 87 cavaleir
The idle of the vehicle is controlled by the idle air control motor located on the throttle body looks like a little barrel with a plug in on the end bolts to the throttle body.
Sep 06, 2009 | 1987 Chevrolet Cavalier 4 Door
2004 Honda Civic -Code P0122 Throttle Position Sensor Voltage Low
yes, this is the case of a failed throttle body, in which case it needs replaced, the car is getting too much fuel causing the high idle. this needs replaced asap. you could proably find a small independant honda shop that could do the work for less.
May 12, 2009 | 2004 Honda Civic
High Idle
The Throttle screw is located on the throttle (obiously) its in a clinderical shaped channel located on the throttle just oposite or obliquely opposite the the throttle body position sensor. In some mazda vehicles (IN TRINIDAD) you need to loosen the throttle body position sensor and slightle adjust it eighter to the right or left to tuen the idle (For electronic controlled axcelleration) in some cases it can be adjusted via an ODB2 diagnostic tool (only in some vehicles that has electronic controlled axcelleration)
You can tell what type your vehicle is by looking for an axcelleration cable connected to the throttle body. If the throttle body has a cable it isnt electronically controlled and has an idling screw. If there is no cable but wires to the position sensor its electronic.
Oct 31, 2008 | 1993 Mazda MX-3
ACDelco 2133859 Throttle Position Sensor TPS 19143600 Logo
626 people viewed this question
Top ACDelco Clothing Experts
ray gallant
Da Doc
Are you an ACDelco Clothing Expert? Answer questions, earn points and help others
