Question about Samsung Refrigerators
Samsung double door srs580 is short circuiting the power...is it the compressor.? when the fridge is on i can't hear any noise
  • 8 Answers
Hi
The problem will most likely be the fridge defrost heater or thermal fuse.
Bryan
Posted on Apr 29, 2015
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
May 04, 2018 | Samsung Refrigerators
Maytag Refrigerator, Vibrating Noise
What is a short time? 5 or 6 secondswould be icemaker fill valve.Tubing in back is a common noise maker ,could be somthing hitting the condenser fan blade.
Nov 27, 2012 | Maytag MSD2434GE Side by Side Refrigerator
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Fridge does not work and called a technician to come have a look at the compressor, it is 100% fine...but the fridge is just off, what can be the problem...its a samsung double door fridge
hi.if u called a technician he should have diagnosed the fault?... well ok ;is the freezer ok?if yes then first defrost the fridge completely and then try.listen for the fan noise on opening and closing door.if the whole fridge is off i suspect the board.good luck.Ali
Jun 27, 2012 | Samsung Refrigerators
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Fridge is not cold
Side by side cooling units usually have 2 compressors, one for the freezer and one for the refrigerator. The refrigerator compressor may be bad, or not pulling enough power, or there may have been a leak in the tubing that the compressor uses to cool the unit with. To diagnose the problem, be aware of the noises the unit makes, and check to make sure it is a 2 compressor unit. If you only hear one compressor running then your compressor is bad, if you hear one running too often, then your tubing is bad, if the back of the refrigerator side is warm but the inside is not cooling down, then the compressor is not drawing enough power. Keep in mind that the radiant heat from the operational (presumably) freezer side may cause the refrigerator side to appear warm. (usually there is a type of wire backing with tubes running along it, these tubes should be mildly warm.)
Jun 15, 2009 | Samsung RM255LASH Side by Side...
Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
76 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
