Question about OEM 2002 Toyota Avalon Radio / CD Player wmf80175u receiver CD & cassette, Delco mfr XL, 6 spkrs Hartford, Massachusetts
My back seat outlet and seat saving control1,2 are not working. Are these controlled by a fuse? If so which ones.
My lighter doesnt work, i have two and one doesnt work
There are actually FIVE cigarette lighter/ Auxilliary Power Outlets shown in the wiring diagrams for your vehicle.
The Instrument Panel [1] Accessory Power Outlet (Cigarette Lighter) is protected by the "LTR" Fuse (# 53 - 20 Amp) in the Power Distribution Center (PDC) in the engine compartment.
The Instrument Panel [2] Accessory Power Outlet is protected by the "AUX PWR" Fuse (20 Amp) In the Instrument Panel Fuse Block on the left side of the dash.
The Center Seat Accessory Power Outlet and the (two) Center Console Power Outlets are protected by the "AUX PWR 2" Fuse (20 Amp) In the Instrument Panel Fuse Block on the left side of the dash. NOTE: If your vehicle is not equipped with the Center Seat Accessory Power Outlet, or the Custom Floor Console (optional), this fuse position will most likely be empty.
Feb 05, 2012 | 2008 Chevrolet Silverado 2500HD 2WD
My cigarette lighter works but none of the 3 power accessory outlets do. Where or what other fuse can I check. Manual does not show a fuse place for the power accessory outlets. Can you help
If its a factory item then it has a fuse in one of the fuse panels, under hood, under dash, on ends of dash, or even under the front or back seats. If its one someone installed then the fuse is somewhere in it's positive wire, stuffed under the dash or behind the console.
Aug 23, 2011 | GMC Envoy Cars & Trucks
I have a 1998 chevy suburban. The dome lights don't work. checked fuse box under hood. All good. Are there other fuses on the truck?
The instrument panel fuse block access door is
located on the driver side edge of the instrument panel.
Pull off the cover to access the fuse block.
The vehicle may not use all of the fuses shown.
Fuses Usage
1 Rear Seats
2 Rear Accessory Power Outlet
3 Steering Wheel Controls Back light
4 Driver Door Module
5 Dome Lamps, Driver Side Turn Signal
6 Driver Side Turn Signal, Stop lamp
7 Instrument Panel Back Lighting
8 Passenger Side Turn Signal, Stop lamp
9 Passenger Door Module, Driver Unlock
10 Power Door Lock 2 (Unlock Feature)
11 Power Door Lock 2 (Lock Feature)
12 Stop lamps, Centre High Mounted Stop lamp
13 Rear Climate Controls
14 Power Mirror
15 Body Control Module (BCM)
16 Accessory Power Outlets
17 Interior Lamps
18 Power Door Lock 1 (Unlock Feature)
19 Rear Seat Entertainment
20 Ultrasonic Rear Parking Assist, Power Liftgate
21 Power Door Lock 1 (Lock Feature)
22 Driver Information Centre (DIC)
23 Rear Wiper
24 Cooled Seats
25 Driver Seat Module, Remote Key less Entry System
26 Driver Power Door Lock (Unlock Feature)
Aug 23, 2011 | Chevrolet Suburban 2500 Cars & Trucks
Cannot locate where the fuse is that controls my cigarette lighter in front console and the passenger back seat. The lighter in the very back of my vehicle works. I want to replace the fuse. My lighter...
Hi, that fuse is in the box under the hood. See pic below. I think it's fuse 32. Fuse 45 also powers those outlets but also power a lot of other circuits. The fuse for the outlet in the very back of the car is on the interior fuse panel, #14. All of this information is in your owners manual. You can download the manual here: http://www.extendedgmwarranty.com/owners-manual/buick/2002-Buick-Rendezvous.pdf
Jun 28, 2011 | 2002 Buick Rendezvous
Accessories outlets don't work but cigarette outlet does on 2003 GMC Envoy
Check the fuses for the power outlets.They are separate than the cigar outlet.They are located under the back rear seat on the drivers side.It will be fuse number 46 for power outlet 1 and 15 for outlet 2.Hope this helps.Good luck.
Mar 27, 2010 | 2003 GMC Envoy
2008 ford escape back outlet
check fro separate fuse in manual
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
May 21, 2009 | 2008 Ford Escape
Aux. Power Outlet
The two outlets are on two different fuses. The one in the front of the console I believe is labeled C/LTR and the fuse for the other is labeled AUX PWR. They are both located in the fuse/junction block in the right side door opening.
I would check them both as I may have stated the labels wrong.
Good Luck
Sep 12, 2008 | 2004 Chevrolet Monte Carlo
Front and center console 12v accessory power outlets not working
look under the drivers rear seat for the rear fuse block it will be under a black box right there
Aug 25, 2008 | 2003 Chevrolet TrailBlazer
OEM 2002 Toyota Avalon Radio / CD Player wmf80175u receiver CD & cassette, Delco mfr XL, 6 spkrs Hartford, Massachusetts Logo
767 people viewed this question
Top OEM Car Audio & Video Experts
D. E. Hev
wadingriver
wadingriver
Are you an OEM Car Audio and Video Expert? Answer questions, earn points and help others
