Question about Orion Televison & Video
What size of screws are needed to mount face plate on the back of a Orion 19 inch flat screen TV. Model #Sled1945 !
    Problem Solver:
  • 11 Answers
The screws for the mount for your TV usually go to Walmart or these other stores ask for the mount of the size for your TV and they usually have every size depends on the size of your TV. If not buy it online put exactly screws for 19 inch orion and the model for the mount and it will show up.
Posted on Oct 26, 2015
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
budmrtn
  • 11361 Answers
SOURCE: Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Posted on Jul 11, 2010
How to find replacement parts for my television base
For 22" or 19" Emerson TV base 3 screws (M4 x 12)
Emerson LC190EM2 User Manual Supplied Accessories Symbols Used In This...
this size may differ for your TV based on its size and quantity may differ based on the design / model of your TV.
could have helped if you mentioned the model number as well.
May 26, 2016 | Emerson Televison & Video
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Orion 46 inch replacement screen
You can try shop Jimmy but likely it would be cheaper to replace the set. Shopjimmy.com.
Mar 18, 2014 | Orion TV 4200 42 in. Plasma TV
When i power up gateway screen is black
Most likely, its a power supply issue. Have fixed a couple of these by replacing bad capacitors on the power supply board. A bad capacitor will have the top bulging, not flat on top as it should be. The way to get the monitor apart is a little tricky. You will need to remove the screws around the top, sides, and bottom, Do Not remove screws on back in the middle. These screws hold the metallic pan that houses the power supply it's self. I used an orange pealer from Tupperware to pray the front face plate away from the back. You can use a screwdriver, if you don't mind a little marring on the face plate plastic. It's not easy removing the front face piece, lots of interconnecting plastic locks all.around the front face plate. Using your pry tool and pulling (you'll need to use a little muscle) to get the front off. Once face plate is loose, you'll notice the screen is connected to the power supply, one in the middle usually can be pulled and disconnected using your hand. I suggest taking pictures before removing the other wires holding the screen to the power supply. At this point, the front plate is removed, and the screws holding the the screen have been removed, wires disconnected, and power supply in view. Best of luck
Nov 10, 2013 | Gateway FPD1960 19" Flat Panel LCD Monitor
Screw size for 32 inch polaroid
Kindly check the operation manual, if not locate one for free download in websites.
Jul 16, 2012 | Polaroid Televison & Video
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Remote code for my new insignia 19 inch tv using a verizon remote
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 10, 2010 | Insignia 37" LCD Flat-Panel HDTV
I have a 37 inch olevia hd tv..It was mounted on the wall but now we want to put it back on the base and cannot find the screws to reattach the base to the tv. Can you tell me the size of the screws?
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Sep 12, 2009 | Televison & Video
Televison & Video Logo
206 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
