Question about Mazda 2008 Mazda3
Wiper will not turn on, but fuses ok - Mazda 2008 Mazda3
    Top Expert:
  • Mazda Master
  • 6,702 Answers
I would search the whole power line, to see how far the power goes, to find any connection, fuse, cable, relay or switch error.
I use a multimeter for that.
Posted on Apr 26, 2015
Why is passenger wiper not returning to hidden place?
The wiper arm has probably slipped off of the motor gears...to fix this, both arms will need to be removed...but first check for a wiper "fuse" Check your owners manual for location...if the fuse is OK, you should still hear the wipers trying to move...after removing both arms, you will have to try the wiper switch and hopefully notice both bases are turning freely...turn the wipers off before turning your car off...this will show you the normal down position...be sure when putting the arms back on that they both remain in the down position before turning them on...hope this helps.
Nov 12, 2015 | 2000 Nissan Altima
Windshield wiper will not move when turned on
Check for a blown wiper fuse, if ok check power to wiper motor,if ok then you have a bad wiper motor or the circiut board.Board is bad about failures
Oct 21, 2014 | 2008 GMC Acadia
Windshield wiper fuse keeps blowing when car is turned on or off
SHORT CIRCUIED MOTOR!!!TAKE THE CONNECTOR OUT FROM THE MOTOR REPLACE THE FUSE AND CHECK.IF FUSE OK REPLACE THE MOTOR.IF U NEED INFO SEND ME AN EMAIL TO SEND U INFO ON HOW TO REPLACE IT.IT IS QUITE EASY!!
Apr 01, 2014 | Volkswagen Beetle Cars & Trucks
Back windshield wiper won't turn on
The rear wiper has a dedicated fuse. It's the 10A R/WIPER fuse in the relay block. This supplies power to the rear wiper and washer switch and the rear wiper control unit. That unit also gets power from the 20A AUDIO (!) fuse in the engine room fuse box. If the fuses are OK, the ignition switch is in the ON position, and the rear wiper and washer switch is turned on the rear wiper should work. If not check all the components described to find where the loss of power is occurring
Nov 15, 2012 | 2005 Kia Sorento
My 99 Ram 1500 keeps blowing the wiper fuse... I think it's a bad ground connection, but need a shematic to find it.
Fuses dont blow for bad connections, the blow because of a SHORT. Disconnect the wiper motor and then turn the switch on. if all is ok, then connect the wiper motor, if the fuse blows, the wiper motor MAY be bad
May 13, 2010 | 1999 Dodge Ram
Wipers were frozen but would not work when thawed
if you turned them on when they were frozen then you may have damaged the motor or linkage to wipers. the first thing to do is to check your fuses to make sure the wiper fuse is good. if not then replace the fuse and try the wipers, also turn key on with engine off, turn wipers on and listen to see if you hear the wiper motor running if you do then maybe something came apart,most linkage snaps together, hope this helpscc019cf.gif
Feb 11, 2010 | 2003 Chevrolet TrailBlazer
I have audi 14 wiper blades are not working
It is possible that the linkage is jammed. Try turning the wipers on and gently pull the wiper arm by hand to see if it will move. It it starts to move you've found the problem.
If it doesn't move at all and the fuses are ok it is likely the wiper motor that has failed.
Jan 11, 2010 | 1998 Audi A4
Dodge Caravan 1990 front Windshield Wipers Don't Turn on.
If the Fuses are good and the Rear Works the Cause will be the Wiper Motor for the Windshield Wipers. Please Rate My Response! Thanks!
Feb 04, 2009 | 1990 Dodge Grand Caravan
1990 Dodge Ram Wiper not working
You did everything else. You have voltage going to motor,so I would say that was it.
Jan 27, 2009 | 1990 Dodge Ram
Mazda 2008 Mazda3 Logo
206 people viewed this question
Top Mazda Car Audio & Video Experts
ka4iup
ka4iup
Tom Chichester
Richard Warren
Richard Warren
Are you a Mazda Car Audio and Video Expert? Answer questions, earn points and help others
