Question about Maytag MEW6530DDW 30" Electric Single Wall Oven with EvenAir
How can i tell if the hi limit thermostat in my maytag wall oven is bad
When I set my oven to bake, I hear the relay switch click then I hear it click again. Neither bake or broil element will get hot. The oven has a new control panel and new temperature sensor. I have removed the Hi Limit Thermostat. I want to know how to tell if this is bad before I replace it.
  • Maytag Master
  • 5,323 Answers
Test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Posted on Apr 29, 2015
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Maytag Model MEW6530 Baking Element
Theck the thermostate, the thermostat is the circuit that activates the heating, and power the baking element , when this is faulty there is no heat or low it, give it a check.
If you need to buy the replacement part, or to locate the thermostat, check on this website, they provide exploded view, so that you can locate the part.
Oct 29, 2008 | Maytag 30" Built-In Single Electric Wall...
Element heats up when we only put oven light on
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
Oven will not shut off just keeps getting hotter
Oven Control Board
Relay board:
May 21, 2014 | Whirlpool WOS51EC0AW 30" Single Electric...
Oven doesn't work (bake nor broiler) checked both heating elements there fine whats next?
With out a model number I was unable to look up any specific information.
First I would look for a thermo fuse on the back side. If you model has one it may be bad. If it's a older oven with a mechanical clock make sure the clock is not set to timed bake.
Aug 03, 2011 | Ovens
O have a aoes3030e and neither the oven or the broil get hot the display shows 170 and you hear a click like something is coming on and then another click like something is going off i do not have any f...
the clicking noise is the relay on the electronic board . and i bleive that the hi limit has failed pt # R0702565 located bening the control panel on top of the oven .. ck htis before replacing other parts ( very common ) mm hope this helped . feed back pls
Nov 24, 2010 | Amana AOES3030 Electric Single Oven
I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Maytag MEW6530DDW 30" Electric Single Wall Oven with EvenAir Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
