Question about Ovens
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Posted on Apr 27, 2015
  • Gail wilson
    Gail wilson Aug 11, 2016
    How press manual button does not work
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
Neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Oct 07, 2008 | Ovens
Ovens Logo
402 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
