Question about 2013 Hyundai Santa Fe - All Santa Fe models - In-Channel Rain Guards
Why do I keep getting a burning rubber smell from the rear offside of my 2013 santa fee.16000 miles on clock,will do this about every two weeks or so
    Genius:
  • 1,138 Answers
Check around exhaust pipes make sure nothing is touching it wires ect also jack car up and make sure that the front & rear brakes are not binding on as this could be causing the smell
Posted on May 14, 2015
Burning smell coming from engine, so strong it is inside the car. Got an oil change about 70 miles ago two weeks ago. It has been burning through oil pretty fast though lately. The smell is like a...
Have you checked the oil,checked to see if dipstick and fuel cap are tight.Do you have oil spots on driveway? Those are the first things I would check,if oil is on driveway is it coming from the oil pan.It 'seems" it May be tied in with the oil change from 2 weeks ago
Mar 05, 2015 | 1999 Subaru Forester
Door locks 2013 hyundai santa fe
The rear door problem is the lock actuator. The problem with locks keep activated when you close driver door. My uncle's Santa Fe has same problem and couldn't fix problem under any circumstances. I even rebuilt the entire lock system didn't help
Jun 06, 2017 | Hyundai Santa Fe Cars & Trucks
Smell of burning rubber on offside rear wheel. Intermittent. Kia Ceed 113bhp 1.6
It could be the handbrake, and easy to check. Next time you smell it, feel the nearside brake caliper or drum, then carefully touch the offside one. You will notice the difference in heat. Under normal use, they get warm, but if it is burning, it will too hot to touch.
Also look under the car for anything near or touching the exhaust. Check mud flaps if you have them that they are not touching the tyre when you are in motion.
May 29, 2017 | Cars & Trucks
I think you are on the right track with the hand brake/ parking brake. A vehicle can still drive if its slightly engaged and you would notice some sort of burning smell from the area. Try engaging the brake and disengaging the brake a few times and see if it releases completely. There may be an issue with the line causing it to "stick" here and there. Good luck! Cars are complicated but troubleshooting the small things before spending hundreds in labour is always wise!
Feb 17, 2013 | Cars & Trucks
Why does my car smell like burning rubber under the hood after i drove it for a while?
could be anything from engine oil on the engine block burning as your driving and coming inside through the air flow from the outside vents, you can always click over the button and recirculate the interior air which will close the vents from pulling air from the motor. Might want to take it in and inspect it, if its not burning oil off the engine somewhere the only rubber would be your tires rubbing somewhere on the wheelwell or the frame and possible melting in that manor.
Feb 07, 2013 | 2003 Hyundai Tiburon
What does it mean when the driver's side back tire is smoking and there's a burnt smell?
there is less load on the offside rear wheel and booting the thottle will spin the wheel,
Jun 15, 2010 | 1997 Jeep Grand Cherokee
My CR-V has a burning rubber smell from the offside rear wheel. What's the problem?
Is the tire worn from rubbing against anything?
Check your rubber boots on the CV joints of that wheels half shaft to makes sure they are not cracked. If the grease leaks out, there will be a lot of heat build up, and stuff will roast. Check wheel bearings while you are at it.
Jan 15, 2010 | 2003 Honda CR-V
Smell of burning rubber rear offside wheel area
Hi there! Check out this link.
http://www.automotivehelper.com/topic175126.htm
this link will take you to a forum full of people with CRV's who are having the exact same problem. It seems to be with almost every year of the CRV as well. Unfortunately Honda has no explanation or solution for this problem. I have a 2009 CRV and have not had this smell, but I have been having a ton of other problems with it. I have been incredibly dissapointed with this car, and will never get another Honda. I hope you have better luck than I, and be careful with it cause I think there are some serious problems with these CRV's. Good Luck!
Jan 12, 2010 | 2009 Honda CR-V
Burning smell
The sulphur smell is the result of the emmisions control system. I have an 06 Expedition with the exact same engine and emmisions system as yours. When the engine is cold, you don't smell that sulphur smell, but as soon as the engine gets to operating temperature, the exhaust gasses smell sulphury. Nothing wrong with your ride - they all do that. The dealership sometimes spray the underbody with some type of rubber to protect the vehicle against rust. This rubber stuff sometimes get sprayd on the exhaust as well and then you will smell "burning tires" after driving the vehicle. This will go away after a few thousend miles though.
May 15, 2008 | 2008 Ford Expedition El
2013 Hyundai Santa Fe - All Santa Fe models - In-Channel Rain Guards Logo
73 people viewed this question
Top EGR Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an EGR Vehicle Part and Accessory Expert? Answer questions, earn points and help others
