Question about Dryers
Fan works, Lights do not. I replaced a bulb and all three went out..replaced them all and still nothing.Fan still works fine.
    Genius:
  • 1,617 Answers
What make/model of fan is it? Are you using the correct wattage? You might have a short in the light kit. Remove it and check for any bare wires that might be touching something.
Posted on Apr 27, 2015
mikedem7
  • 25 Answers
SOURCE: Hampton Bay ceiling fan
You have a dangerous electrical situation call an electritian to test the wiring.
Posted on Aug 20, 2008
  • 89 Answers
SOURCE: Ceiling fan lights won't work
Possibly, your switch has a short in it.Outside of that, it may be a broken wire somewhere. Hope this helps. Good luck.
Posted on Aug 25, 2008
  • 9 Answers
SOURCE: 40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: I have a 52
u have a short in that socket. don't put other bulb in there because you might blow the whole circuit if u keep doing that.
Posted on Mar 10, 2009
sk8er1707
  • 58 Answers
SOURCE: fan works lights dont
It's most likely that when the bulb burned out the electrical heat got to the socket causing the emergency shut down of the lights if you take of the light casing there should be a small switch next to one of the bulbs all you have to do is flick the switch, put back the casing and walla your lights should work (hopefully lol =])
Posted on Jun 06, 2009
Battery on remote went dead. Replaced battery. Fan works fine, but lights will not come on. Tried resetting by turning off and going through the fan settings, but problem continues.
If you have a pull chain on the light, make sure it's in the on position. Also, try different bulbs if that doesn't work.
Jan 13, 2016 | Dryers
Lights just stopped working?
Could be a faulty switch or loose wires where they are wired together.
Jun 28, 2014 | Hunter 52" Ceiling Fan With Light And...
Main beam lights not working
It's possible the "main" lights elements have burnt out.
I believe it's a single bulb per side with both high and low beam elements inside.
Try replacing a bulb and see what that does.
Mar 15, 2014 | 2007 Ford Fiesta 1.4
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Lights are out
The manufacturer is King of Fans. Their number is 800-330-3267.
Nov 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Aug 25, 2008 | Aloha Housewares (93645) Ceiling Fan
Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Oct 30, 2007 | Sony VPL CS1 Multimedia Projector
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
