Question about Eiki Office Equipment & Supplies
Eiki lc-se10. No power indicator light. I changed the fuse. Any ideas on what could be wrong?
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: EIKI LC-XNB1 BRIGHTNESS
Hi Will39
What you should keep in mind is that this Projector has only got 800 Ansi Lumens wich is not much and to make this worse it is a LCD Projector as well.
Ask your lamp supplier if they can insert a new lamp and check if it gives a better image at all.
If it doesn't , there is'nt really much you can do except buying a new unit with more Ansi Lumens and a better Contrast Ratio as this Eiki's Contrast Ratio is only 250:1 where the standard these days are 2000:1
Posted on Mar 26, 2008
projdoc
  • 2236 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
projdoc
  • 2236 Answers
SOURCE: EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
stecon3248
  • 57 Answers
SOURCE: plug in and green light
Check the lamp. If it is not blown then there is a problem in the lamp ballast circuit and the projector will need to be serviced.
Posted on Aug 15, 2010
Why won't my warning light turn off?
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Oct 25, 2012 | Eiki LC-SE10 Projector Multimedia...
Have Eiki LC-X1000 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, 230 AC ok and 300 DC volt ok, No standby light, nothing,then what can i do
dried out smd capacitors in primary part of power supply , common problem with this and similar models. 1uf, 2.2 uF and 1 radial 220 uF
replace bij 105 oC type
Apr 05, 2012 | Eiki LC-XG250 LCD Projector
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
63 people viewed this question
Top Eiki Office Equipment & Supplies Experts
Jaime Hernandez
color wheel light...
Jerry Kramer
Jerry Kramer
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
