Question about Therapure Four Person Inflatable Round Hot Tub
Shuts down when I push heater button and will not heat up. I cannot find a heater element.
  • 21 Answers
It means your pump has lost a speed, or gone out completely. There is no heater element on these spas, they use the heat from the motor to heat the water. There are some options if it makes a humming noise when you try to hit jets...
Posted on May 06, 2015
Testimonial: "Can I fix it if there is no humming noise?"
  • Nick Smalling
    Nick Smalling May 18, 2015
    No, you will need a new pump most likely. If it humms you can sometimes replace the start capacitor on the motor. To ensure it is your pump and not the controller you would need to check voltage at the pump connector with a electrical tester.(Do not do this if you have never used one before) or ensure that the pump never runs, eg when you hit jets button, turn thermostat up or down. If the pump runs at all when you hit other buttons, it is not your pump, this is all if you have a 1 speed pump. You need to verify that when you hit the heat/jets button, that you have 120v between the black and white wire that go to the pump. If there is 110-120 volts and it is not running, it is the motor, if not it is the board.
  • 1,631 Answers
These Toy style spas do not have individual replacement parts for their major components, available or easily attainable by the consumer! It appears that when they fail so early and prematurely, they want you to buy a new pump, or heater, or control center, etc.
I would squeak and squeak to them until that squeak is oiled! Especially if fairly new. But I wouldn't hold my breath.
Good luck.
look here...
http://www.intexcorp.com/support
Why won't it start?
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
Sep 24, 2015 | Heating & Cooling
Over heats and shuts off
The top thermostat controls your water heater meaning if it is not working you wont have any hot water. If the top t-stat needs to be reset by pushing button in then check the element with POWER OFF and remove wires from element. check ohms should be around 12 to 19 ohms. If ok then reconnect wires and check amps. turn on power and use clamp on meter for amps. 15 to 20 amps should be ok. if not drain heater and pull out element. while you are at it drain all the water and pull lower element. if replaced and you have some hot water then quickly cool or cold then you have a broken dip tube located under the cold side of the supply line. they are cheap and easy to replace. I hope this helps.
Apr 19, 2014 | Rheem Water Heaters
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
I have a Reliance 501 electric water heater. There are two panels. In the top panel is a red "reset" button. On two occasions this button has popped and turned off the unit. I have pushed the...
ECO reset button trips when thermostat senses high heat event over 150 degrees F, or when upper or lower thermostat is defective. There are other causes: if tank access covers and insulation are missing, and when element is shorted to ground in center of element so that element continues heating through one leg of 240V circuit after thermostat turns off.
Ordinary tank-type electric water heater is fully repairable by homeowner using generic parts from hardware store or home center.
1) Replace upper and lower thermostat for about $28, and if problem persists, then do troubleshoot shown in step 2 below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Take 30 minutes and troubleshoot before replacing any parts.
Troubleshoot requires cheap multimeter from home center.
Install battery in multimeter.
When testing voltage, rotate multimeter dial to 240 or 250 or 277 VAC.
When testing continuity or elements, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jan 13, 2011 | RELIANCE ELECTRIC WATER HEATER
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If upper element is burned out the tank will not heat any water.
http://waterheatertimer.org/How-it-works.html
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have change the bottom heatern and the bottom thermostat but the bottom heate do not have current even if the top heater and thermostat have current.
There will be no current to bottom element until top element shuts off. then top thermostat will send current to bottom element only after the top half of the water heater has heated up and shuts off current to top element. Only one element at a time can be on. If current still does not go to bottom AFTER top element shuts off, the top stat could be bad.
Dec 28, 2009 | Water Heaters
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Whirlpool DUC600XTPQ6 Quiet Partner I
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Dec 01, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Therapure Four Person Inflatable Round Hot Tub Logo
1,437 people viewed this question
Top Therapure Pool & Spa Experts
The Cover Guy
The Cover Guy
Tom Chichester
J.D. Browning
J.D. Browning
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
