Won't spin- drains etc but won't spin and motor makes humming noise as if not engaging the tub. tried balancing load, leveling and still same result. does this model even have a belt? can I fix this?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Capasator probily
Posted on May 03, 2015
My machine rattles and shakes during the spin cycle and automatically shuts down. It seems to progressively getting worse. It doesn't seem to matter how big or small the load is.
the things to check are
is the machine still level
are the suspension insulators for the tub in good condition as the machine may be level but the tub is not
the level is of utmost importance in washing machines
Jan 12, 2017 | Washing Machines
Grinding noises
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 19, 2015 | Washing Machines
My washer is getting louder and louder
By the way my advice is free cuz God is good!
Mar 23, 2015 | Kenmore Oasis HE 27082 Top Load Washer
Washer is loud when spinning out
Aug 20, 2014 | Whirlpool Washing Machines
My ultimate care 2 washer is full and makes. a loud noise when I turn it on. Nothing happens. It doesn't drain
Aug 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I fix a loud noise during the spin cycle in my whirlpool duet washer ghw9400plo?
Aug 06, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer making loud noise. Shuts off, not draining.
It appears that you have an imbalanced load, or a nearly balanced load with a machine that easily goes off balance during spin. I would suggest:
1. After the unit trips on imbalance and stops spinning, open the lid and redistribute the laundry load inside to balance its weight equally around the interior of the drum. Note that cotton fabrics hold much more water than synthetics, and this has resulted in imbalanced loads even though they visually appear to be balanced. Close lid to restart spin.
2. Remove the front panel and check both tensioning/centering springs on the sides of the tub. A loose spring could easily cause the machine to go off balance.
3. Finally, check the main bearng play by holding the drum steady and moving the top of the agitator spindle horizontally toward the rim of the tub. Any excessive play is a clear indicator that bearing is excessively worn and may be resulting in an unbalanced load.
Oct 05, 2009 | Maytag Washing Machines
Whirlpool Washing Machine won't spin
Sounds like motor controller or motor either way it's not cheap...Sorry
Mar 13, 2009 | Whirlpool Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
