Question about Garden
Where is the diagnostic port located on this loader
    Top Expert:
  • 10,875 Answers
Wherever the manual says it is
Posted on Apr 26, 2015
Where is the diagnostic port of my mazda premacy 2000 model located
Typically the OBD2 port is located below the steering wheel, towards the right or left knee. It should have a cover over it saying "diagnostic" or "obd2" another location is under the hood, typically near a fuse panel. This one should definitely have a cover on it saying "diagnostic" or "obd2"
Feb 15, 2016 | Mazda Cars & Trucks
Diagnostic port
check here for the location of the diagnostic port
http://codes.rennacs.com/Petrol-Engine/Japanese-Korean/Kia-Engines.php
Apr 16, 2014 | 2005 Kia Carens
Locate diagnostic port
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $0 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Mar 28, 2014 | 2001 Ducati 900 SS i.e. N-C
The diagnostic port is not reading
Just fixed mine- Cigarette lighter had a blown fuse , which is also the fuse for the diagnostic port. Check your owners manual to locate diagnostic port fuse,
Nov 30, 2013 | 2004 Lincoln Aviator
Looking for the diagnostic plug location on a 1993 525 it
SORRY, FOR 1993 BMW, THERE IS NO PLUG FOR DIAGNOSTIC TOOL,
or you can ask the 24 hrs live technical support http://www.diyobd2.fr/ they will like to help you, good luck
Sep 15, 2013 | BMW Cars & Trucks
Diagnostic Port Location
THE PORT SHOULD BE TO THE RIGHT OF THE STEERING COLUMN. THERE SHOULD BE A RECTANGULAR HOLE IN THE COVER THAT IS UNDER THE DASHBOARD .LOOK HARD WITH A FLASH LIGHT AND YOU WILL FIND IT.GOOD LUCK HUNTING.
Apr 11, 2012 | Cars & Trucks
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
Where is the diagnostic port located on my 2001 passat 5 sp. auto V6?
On the old Volkswagen Passat B5 (MY 1997-2001) the Data Link Connector (DLC) or diagnostic port is placed on the right side of the parking brake lever, under a small rectangle rubber cover. See pictures below:
On the new Volkswagen Passat B5 (after MY 2001) the Data Link Connector (DLC) or diagnostic port is placed on the panel above pedals. See pictures below:
Apr 06, 2011 | 2001 Volkswagen Passat
This is an error in the ink loader.
It usually means the ink count sensors are stuck, after using 2 - 3 ink sticks. Your code shows that the yellow ink loader is stuck.
Features on the bottom of Xerox ink sticks actuate the ink loader sensor located at the end of each ink loader channel. The sensor detects the movement of the ink sticks to keep a record of ink usage.
Damaged, or Non-Genuine ink sticks may not actuate the sensors. Or using older Phaser 8400 model ink will also cause the 9,03x.4x errors.
  1. Check the ink sticks are genuine, and for the correct model.
  2. Manually verify that the ink stick is able to move in the ink loader chute. Check for broken or incorrect ink sticks.
There is a small chance that the ink count sensor is faulty, or the ink heater has blown.
This fault has to be cleared by running the Clear ISC Fault function, in the Service Diagnostics Menu.
Service Diagnostics > Function Menu > Clear ISC Fault
To enter the Service Diagnostics Menu, start with the power OFF.....
1. Turn the printer power On.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold
the Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization. Release the buttons and the printer reboots into service
Have Fun!
May 11, 2010 | Xerox Phaser 8560DN Laser Printer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
