Question about Boating
Water is not spitting out of the rear of the motor. Is this normal? Boat is not overheating.
    Top Expert:
  • 10,875 Answers
Not normal
Posted on Apr 26, 2015
Kenmore dishwasher making "spitting" or "sputtering" noise during operation
The easiest way to confirm if the arms are blocked is by turning all the arms in the machine to a certain same position and running the machine for a few minutes in its wash cycle. Open the door and see if the arms have moved. If not, check all the holes in the arms for blockages. Sometimes its very difficult to clean them. You may have to poke a pin or something into hole and then shake the obstruction out through the large inlet hole under the spray arm itself.
Dec 23, 2014 | Kenmore Dishwashers
Engine overheating
Water pump, which is located in bottom shaft housing near the prop, could be going bad and not suppling enough water to cool the engine
May 18, 2014 | Boating
I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
Water is not coming out of both water jets
Hi. It could be a clogg in the lines. Check and clean out. Also check that pump is running properly.
Aug 19, 2012 | Motorcycles
My car overheated, now it registers hot immediately whenever it starts, spits coolant out and even has water coming out of my exhaust. I tried draining & flushing then using the block sealant, but...
u have a blown head gasket and probably warped the clyinder heads...im sorry to say u probably need a new motor...the coolant being spitted out is caused by the engine forcing combustionchamber gases into the cooling system
Jul 12, 2011 | 1995 Lexus ES 300
I bought a boat with two 60hp mercury efi on that was based in the salt water for three years. one motor have a flow problem.the alarm comes on and the rpm drops due to the motor overheating. i fitted a...
Mercuries have notoriously small waterways in the head and suffer seriously from this problem in salt water.
I cant suggest anything except to strip the motors completely and physically clean out the waterways. Sorry about that.
Jun 01, 2010 | Boating
Yamaha Exciter jetboat: eng stops when warm, not overheating
I have a 1998 Yamaha Exciter jet boat as well and am having a similiar problem. I just took it in today and the mechanic believes that it may be the oil pump failing which causes the pistons to stick and not lube the engine properly, thus causing overheating and eventuallly stall. The one motor sounds beautiful and the other sounds unhealthy. He checked compression and it seemed fine and it has new plugs. Maybe this is the same problem you are having...Hope this helps...
Mar 24, 2010 | Yamaha 12V Air Pump
Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Motor fires off great and run good but at full speed after 15 mins it dies and won't start after 10mins it will start but at hight speed only after i get it going run good at 1/2 speed
What Year? Have the coils checked, they are located under the flywheel, some have been known to act up over time due to heat because of age. They time between dieing and restart souns like they had time to cool off until overheating again
Apr 17, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
129 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
