Question about Boating
I'm looking for draft , weight capacity specs etc. I just purchased a 1990 24' spectrum pontoon with a 120 merc. Thanks, Duane
3 Suggested Answers
  • 105 Answers
SOURCE: Im looking for full specs (hp, tow capacities,
depends on engine,probably a 305,210 hp 5 to 6 k towing,350 engine,240to 260 h.p.7 to 9k towing cap.
Posted on Jan 25, 2010
Molson02536
  • 3854 Answers
SOURCE: fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Posted on Feb 09, 2010
Max weight carrying capacity -Sterling Pearl scooter
Hello I looked up the specs on this and the max weight for this scooter is 136kg or 300 lbs (give or take a few ounces) you may find this information here:
http://www.sunrisemedical.co.uk/mobility-scooters/sterling/mobility-scooters/pearl
Hope this answers your questions.Have a great day.
Sep 26, 2017 | Health & Beauty
Purchase a used South Bay pontoon 250 4 stroke merc . When you just turn the key it automatically tries to start then it stalls and then try by it self to start up again but will not stay running why
Check the wiring at the ignition switch, and the switch itself.
Sounds like you have loose wires that are losing connection, and shorting on each other.
Sep 05, 2017 | Boating
What should the tilt be set at for a 12 ft pontoon with a 15 hp motor
Bill,
The tilt is dependent on weight in the boat, location of people, etc. The majority of people set it by feel. For a pontoon with low horsepower a general setting is set it so the propeller is horizontal to the floats (pontoons). Since you only have a 15hp on it I would set it this way. That way your propeller is pushing water straight back and all power is utilized in moving the boat and not wasted on raising or lowering the bow/front of the boat under power which is what your tilt up or down does. Raise it up your bow goes up. Tilt it down and your bow goes down.
Fred-
Aug 06, 2016 | Boating
Whats the difference between the taveler plus and the traveler plus HD other then 25lbs. The specs look the same and the weight is the same
Well you got it the difference is weight capacity the HD will support 25 more pounds than the plus Hope this helps
Oct 13, 2010 | Pride Go Go Elite Traveller Plus HD 4...
What is the towing capacity of a toyota sienna?
2006 Sienna Standard towing specs:
2WD or 4WD: Max Tongue Weight: 200 lbs
Max trailer and cargo weight: 2,000 lbs;
(over 1,000 lbs requires trailer brakes)
Max trailer and cargo weight: 3,500 lbs WITH the factory tow package
Thanks for using FixYa!
Feb 16, 2010 | 2006 Toyota Sienna
I need to manufacture a boat trailer for a
I have some tips I learned from finding a trailer for my 27 foot cruiser. Really, you can find deals in this economy that make rigging a trailer from scratch too much work.
You need to find the loaded weight of your boat and where the hull needs support from Carver. Your trailer needs to hit the "Chines" correctly, meaning the bunks have to be adjustable to the contours of the hull.
The bunk supports can fit outside, inside, or on top the frame rails Mine started on top of the rails and were converted to the torsion axles, requiring new supports.
The axles need to support enough weight and State laws will say how many axles need brakes. Your choice of electric or hydraulic. The bunks should be made of Cypress, but synthetic decking could be cheaper. Your tires should Load rated D or better and 15 to 16 inch wheels, not 14 inch because of the weight.
There are numerous Boat Salvage yards listed online.
There seems to be a "thing" about the region the boats are used. Some places have orphaned trailers everywhere and others are always married to a trailer.
I have seen Boatyard liquidations with ridiculously cheap trailer prices. Use the internet and look.
Feb 06, 2010 | ShipShape Pontoon Boat Trailer Guide-on...
2008 mercedes benz ml63 amg oil consumption problem
Is the merc dealer serviced??, sometimes if you change brands of oils in synthetics >>semi synthetics you will get excess oil useage. City driving will tend to use more oil, but the merc should be able to do its 10,000k betwwen oilchanges.
Anyway, check what oil is being used in both weight example 0-60w, 5w-30 etc and by brand, check that the API oil spec meets what is required for your vehicle example API SM, SJ, SL etc.
Jun 25, 2009 | 2007 Mercedes-Benz ML63 AMG
1994 Suzuki King Quad Timing Specs?
I need a manual or specs how to set the timing on a 93 Suzuki King Quad 300 ATV. Timing chain broke, bought a new one, jumped time. Need help.
Jan 08, 2009 | 1994 Suzuki DR 350 S
Towing capacity
Directly from the Toyota Spec Book:
Maximum trailer weight: 1,500 lbs
Maximum tongue weight: 150 lbs
Hope this helps; and, thanks for choosing FixYa!
Oct 25, 2008 | 1997 Toyota RAV4
Tow capacity
For Jeep Cherokees 87-97 Hope this helps thank you for using fixya.com
Tech Information:
http://www.suspensionconnection.com/cgi-bin/suscon/027.html
Weight Carrying Capacity Weight Distributing Capacity * Gross Trailer Weight Tongue Weight Gross Trailer Weight Tongue Weight 3500 lbs. 300 lbs. 5000 lbs. 500 lbs. * Weight Distributing Capacity requires utilizing a Weight Distributing System on a hitch.
Note: Never exceed the towing capacity of your Jeep Cherokee. Please refer to your vehicles operation manual for actual vehicle towing specifications.
Sep 29, 2008 | 1986 Jeep Cherokee
Boating Logo
441 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
