Question about Makita Saws
Not cutting accurate in the A position sawing to the right of my pencil line
    Top Expert:
  • Makita Master
  • 10,875 Answers
So,remember that and move the wood to the left or find someone that knows how to operate a saw
Posted on Apr 26, 2015
  • 2 more comments
  • gary ferguson
    gary ferguson Apr 29, 2015
    you obviously dont no what your talking about
  •  johnny rebel
    johnny rebel Apr 29, 2015
    take the blade off,then take the outer flange off,then put the outer flange on after the blade then put the bolt on
  •  johnny rebel
    a is the right side,b is the notch
  •  johnny rebel
    http://www.makita.com/en-us/Modules/Tool...
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 | Saws
Tip
My Blue Laser
Ever wish you could make that perfect cut the first time with your miter saw or table saw ? Simple if you put a strip of wide blue tape on base of saw and cut the tape with your saw ! Now you know where the blade will cut, now mark your wood, move the wood and the pencil mark to edge of tape that you just cut and cut it. That simple and easy to calibrate verses the red lasers that come on some saws that to me never work right to begin with.
Valley2118
on Feb 19, 2010 | Saws
Saw not cutting accurate in A position cutting to the right of the pencil line
you are cutting to the right,the mark on the saw is only a reference,it is up to you to figure where to saw
Apr 26, 2015 | Makita Saws
Cuts unevenly
This is probably because the offsetting tapered discs in the dado are not lined up to compliment each other and your dado is tipping more to one side than the other - if the blade was tipping to the left and right the same amount, both sides would cut to the same depth and the deepest part would be right in the middle. In an extreme case, if the blade tipped only to the right and not to the left, then the left side would cut the deepest and the bottom of the cut would curve up (shallower) to the right.
The same effect could be due to your arbor not being set exactly at 0 or 90 degrees. The angle indicator on the saw is usually not very accurate. Put a regular blade in, raise it up all of the way, then check for squareness between the table and the side of the blade (using a known good square). Adjust the tilt until you are good, then put the adjustable dado back in.
Sep 04, 2012 | Oldham 7005012 7 Inch Adjustable Dado...
I believe my table saw blade is not accurately aligned with the table and I can't find my Owner's Manual.
OK, first you should understand that the blade needs to be aligned with the miter slot. The easiest way to check this is to use a ruler.
UNPLUG YOUR SAW BEFORE BEGINNING!
First, use a pencil or a marker to mark the outside of one of the teeth on your blade, on the same side of the blade as the miter slot you're going to measure from. Position the marked tooth at the front of the table, then measure from the side of the marked tooth to the leading edge of the miter slot. To determine if it is aligned correctly, you simply spin the blade around where the marked tooth is at the back of the table and measure it again to the leading edge of the miter slot. The measurements should match. If you want to be more accurate you can use a machinists dial gauge to measure within 1/1000 of an inch.
If the measurements are off, you need to loosen the trunion bolts that mount to arbor to the table just slightly, then use a dead blow to move the table in the appropriate direction.
Search youtube for "table saw allignment" to find lots of videos showing this technique.
Also, here is a copy of your owners manual:
http://www.homedepot.com/catalog/pdfimages/c2/c2e26e29-35a4-469c-8193-136092afdbd3.pdf
Jun 30, 2012 | Ridgid 10 in. 13-Amp Professional Table...
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Saws Logo
261 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
