Question about Invacare Supply Group Pronto M61 Standard Power Chair
I have a pronto m6 , I replaced the batteries and it will move and turn ok but is real slow and no power .
  • Anonymous May 06, 2015
    I figured it out, put the seat all the way down.
  • 68 Answers
Test the battery voltage at the joystick where a programmer or charger would plug in. There are 3 holes, the top or number one hole is the positive hole for a voltage meter to plug into and the bottom or number two hole is the negative hole for the volt meter. Plug in the meter and see what the voltage is when sitting still and keep the meter in and see what the voltage does while you are driving the chair. The voltage should not drop more than 1 or 2 volts from that which you had when the chair was not moving. If the voltage drops more than that then there is a problem with charging or the new batteries. If the voltage remains good then the joystick or speed knob control could be the problem.
Posted on Jun 25, 2015
5 Suggested Answers
  • 692 Answers
SOURCE: invacare pronto m51 moving very
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Posted on Aug 17, 2010
HoverTech
  • 232 Answers
SOURCE: I have a Pronto M6
Make sure all of your connections are tights and the your fuses do not need to be replaced.
Blinking lights on the controller usually indicates a problem, the number of blinking lights are used to diagnose the problem. Take a look at this website to identify the type of controller you have on your scooter so you can dtermine what the blinking lights are trying to indicate.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Posted on Oct 13, 2010
  • 692 Answers
SOURCE: pronto M6 chair will not work. When the power
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Posted on Apr 12, 2011
  • 692 Answers
SOURCE: the controller of my pronto
tony You're gonna have to get a new one sorry
Posted on Apr 28, 2011
What does 1 red flash followed by 5 green flashes mean on a Pronto M6
1 red + 5 green is left parking brake fault. This is a pretty generic code and can be something as simple as the brake/clutch lever is in free-wheel, or it can mean something more significantly wrong, depending on how it is wired in this model. (We don't work with Prontos a lot here.)
May 02, 2014 | Invacare Supply Group Pronto M61 Standard...
I need a seat for my pronto m6
check around at as many nearby DME providers as possible. most have an old seat or two in stock. ask to take an old one off their hands and bargin with them. most have one they'll like to get rid of to make space
Oct 30, 2012 | Invacare Pronto M51 Power Wheelchair
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
I have a Invacare Pronto M6 powerchair that is not working. I've charged the batteries with an external charger. The power lite is flashing red once, then green 3 times. Any help would be appreciated. ...
Marilyn Not having worked on many M6 chairs in a long time I would venture that you have a left motor error indicated by the 3 flashes however since you don't have a indication of full power you might have a battery problem because a low battery can cause the chair to flash also. If you can get someone with a digital voltmeter to measure the voltage at the charger port on the joystick it will let you elimitate the batteries as the problem. Place the voltmeter to 200 volts dc and plug the leads into the two outter holes in the charger port the reading should be 24-27+ volts if the batteries are fully charged. If you are not getting anything or a very low reading then that could be the problem. Replace both batteries with U1 batteries. After yo replace the batteries and charge them before use then turn the chair on and see if you are getting the smae flashes If you are then I suspect it is the left motor and it will need to be replaced,\. Hope this helps you
Nov 08, 2010 | Health & Beauty
I have a Pronto M6 wheelchair that is not working. I called technical support and they suggested it needed new batteries and that the batteries should be replaced yearly. I installed the new batteries...
Oct 12, 2010 | Invacare Supply Group Pronto M61 Standard...
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
Lights flashing
Are you sure that your batteries are not just able to hold a charge? Flashing lights and slow motion are typical indicators.
Aug 27, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Supply Group Pronto M61 Standard Power Chair Logo
267 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
