Question about Ovens Ovens
After cleaning top oven the unit died in both top and bottom ovens
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Check the timer has not accidently been set to auto this would cut the power to your ovens you need to set it back to manual.
Posted on Apr 27, 2015
Kitchenaid selectra
possible but unlikely. they are physically connected?
Mar 07, 2014 | Ovens
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
I own a whirlpool double wall oven. The top is self cleaning but the bottom is not. I purchased this oven in early 2005. Today when I tried to use the self cleaning feature the entire oven went off but the...
Sounds Like the clock control unit may be bad, or the auto latch assy itself. I may have the part for you. What is the model number of the unit?
Sep 15, 2010 | Whirlpool Ovens
Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
rdjagger
ray gallant
Are you an Oven Expert? Answer questions, earn points and help others
