Question about Ovens
When I press bake, broil, etc. display says Feature not avalible
    Top Expert:
  • Ovens Master
  • 46,369 Answers
With no make or model listed we can offer no help . SORRY
Posted on Apr 26, 2015
When I select bake, broil, etc, I get the message-feature not available
If is 6 months old call for warranty repair, turn off circuit breaker for a minute then repower this may clear it if not again call for warranty service
Jan 30, 2014 | Whirlpool RBD305PD Electric Double Oven
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
The temp for bake says 200c what do I set it on for 375 degrees?
265c63b.jpegPress BAKE and BROIL hi/lo
pads for 2 secs till display
show "SF".
Press BROIL hi/lo pad. The
display will show "F", if yall
want "fahrenheit" then hit
START. Press Boil hi/lo again
and yall will see a "C", if
yall want "centegrade" then hit
START. Most stoves.
If you ha listed a make and model it woulda been much easier.
Sep 21, 2010 | Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
