Question about LG WM2701HV Washer
No power but a de code when I spin drum - LG WM2701HV Washer
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
DE error code shows that there is a problem with the door latch assembly. If this latch switch does not work, the machine will not turn on.
Check the continuity of the door switch with a multimeter on OHMS.
Posted on May 05, 2015
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
Wm2701h washer no power but when I spin drum get a de message but filter is clean and all water has drained
The dE error or fault code indicates that the door is not latching properly. If the door latch is faulty, the machine will not turn on. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Apr 26, 2015 | LG Washing Machines
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
My indesit 6105 does not finish with a final spin but everything else works and the drum spins up to this point. This means that the clothes come out very wet
There is fault on the final spin as it fails to dry or drain off the water from the clothes. It is possible that the RPM for the spin is not adequate or the timing is short. Please choose a different program to confirm. Also check for free movement of the drum or else use a de-greaser to the drum spindle bearing assembly.
Aug 02, 2013 | Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Hi, my Samsung Washing Machine does not want to spin after it has done the rinse cycle, it gives me a dE error code. Please help?
The De code is a door switch error. The door switch is broken or a wire to the door switch is loose or broke. The door.. should be closed while your machine is in spinning mode, thats a safety feature so nobody gets hurt while spinning, if you open door the spinning should stop.
Check your switch by ohming it with a voltmeter http://www.ehow.com/how_5371933_test-switch-ohm-meter.html
If its not the switch, then its a wiring problem..Makes sure the wiring has a power source, by connecting the wires in series with a voltmeter ..
Mar 10, 2011 | Dishwashers
LE code is flashing when I try to run the machine
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 25, 2010 | LG WM2277H Front Load Washer
I have a lgwm 2677hbm washer and got a code read out de .i looked it up and it said drain error,i cleaned the drain filter but it sounds very loud during the rinceand spin cycle and i dont know if this...
It is not likely an object got past the filter before the pump, so I'd guess that the impeller has come loose from the pump motor shaft. Replace the pump motor. (washer will not spin if water is still in drum)
Nov 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
LG WM2701HV Washer Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
