Question about Braun Coffee Makers & Espresso Machines
I need the top lid for replacing the present one,where to order for a news one.
Model KSM 2,
  • Braun Master
  • 5,631 Answers
Check for your replacement in this page
https://www.google.com/search?q=Model+KSM+2+Braun+Coffee+Grinder+replacements&tbm=isch&tbo=u&source=univ&sa=X&ei=keg8VbXIJYa0sAS0ooHABQ&ved=0CDcQsAQ&biw=1440&bih=758
Posted on Apr 26, 2015
Need a replacement lid for KSM 2 - 4041
Maybe you'd find your answer a little quicker if you posted your question somewhere besides the refrigerator forum.
Dec 15, 2013 | Braun KSM 2 Electric Blades Grinder
Where can I buy a new blade for a Braun coffee grinder Model KSM2 ?
Try ereplacement.com. There are blades listed for $3.49 but I have never ordered from them.
Aug 19, 2012 | Braun KSM 2 Electric Blades Grinder
How to replace a lid switch on a kenmore washing machine
The following link explains how to replace a lid switch on a Kenmore top loading washer:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. Prices will vary between sites so shop and compare. The first three sites on the list also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions about this repair, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Oct 07, 2010 | Kenmore 22422 Top Load Washer
Replaced timer but the problem stii present. Will fill water and run thru wash cycle but the nothing. will not spin will not ren in rince mode. what is the problem?
The most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
repairclinic.com
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
Aug 12, 2010 | Whirlpool Washing Machines
Won't go into rinse and spin cycle
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
repairclinic.com
Your model number is actually "110.22622100". Use this as your search criteria if you order parts on line. The part number for a replacement switch is 3949238. The actuator part number is 350733.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jul 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer model #23922200 ser 3414819 waher fills and wash but it does not spin or let the water out . What part do i order and how to change it
If the washer fills normally, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike.
This is the most common cause of the problem you just described. Symptoms may also include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
repairclinic.com
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. The part number for a replacement switch is 3949238. The lid actuator part number is 350733.
Jul 01, 2010 | Kenmore 23822 Top Load Washer
My whirlpool ultimate care 2 washer fills with water then does nothing else it wont wash drain or empty
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 8054980.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Coffee Makers & Espresso Machines Logo
530 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
