Question about Schlage Sat Ni Plymo Handle Set
I have a wire caught under the spool assembly of my electric flym strimmer
How do I remove spool holder from drive shaft?
Depends on make and model. Most electric strimmers have a removeable cover over the spool. This cover has 2 pressable tabs that releases the cover that then lifts off exposing the spool. Some spolls are clipped into this cover, others sit on the drive shaft from the motor. In both cass the spool should lift off / out. Make a note of the direction that the cutting line is wrapped around the spool so that you can re wrap it correctly with new line. Hope this helps
Sep 15, 2016 | Garden
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
Strimmer instructions
some strimmers have two tabs on either side of the spool which yousqueeze while pulling up.
Sep 07, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
Where can i buy a replacement spool
do you mean the spool or the trimmer 'wire'? the wire itself can be bought at most DIY shops and then fitted to your spool, which is removable. if you need the spool, contact the maufacturer, or do a web search.
Sep 12, 2009 | Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Schlage Sat Ni Plymo Handle Set Logo
443 people viewed this question
Top Schlage Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Schlage Hardware and Accessory Expert? Answer questions, earn points and help others
