Question about Dewalt Garden
Where can I purchase a manifold for a Dewalt pressure washer model dxpw3025? I am pretty sure mine froze and busted this past winter and sprays out in a couple places on the manifold.
The cracks where the water sprays out are not visible with the eye and a magnifying glass.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Try www.ereplacementparts.com/Dewalt I think they'll have what your looking for.
Posted on May 01, 2015
Dxpw3025 motor drops rpm when triggers pulled
Look at the size of your spray nozzle, it may be too small causing excessive back pressure and thus excessive strain on your engine. Your nozzle should be a 3.0. If you are using the 25 degree nozzle for example, it should say 2503 on the side of the nozzle.
Nov 26, 2016 | Dewalt Pressure Washer - DXPW3025
How do you find manufacture date
there should be a metal plate with numbers. or numbers stamped on the engine cover. if you take these numbers to a parts store they can cross reference the and tell you what you need to know. that is how i find out. good luck
Dec 30, 2015 | Dewalt Pressure Washer - DXPW3025
My powerwasher Generac model# 0060223 is spraying water I think from the pump. Any ideas as to what is wrong.
if you did not winterize it it might have froze up and busted I was given one years back that si what happened to it before I got it and luckily I was able to fix with some lock tight spread on a thin layer and clamped it tight for several days to cure out
Apr 17, 2015 | Generac 6022/5989 2700 PSI 2.3 GPM 196cc...
The machine shuts off when you let off the trigger. Seems like pressure must build up and it shuts off.
Your unloader bypass system has failed. Several pumps were used on this model, see link for parts breakdowns.
Sep 28, 2014 | Dewalt Pressure Washer - DXPW3025
How do you adjust the pressure?
get larger nozzles, if you are using size 4 nozzles now ( looks right for 3 gpm at 2500 psi) then you would use size 4.5 for 2000 psi, size 5 for 1600 psi etc
Chart here https://www.stens.com/assets/media/pdf/2012_Nozzle_Size_Reference_Guide.pdf
Sep 07, 2014 | Dewalt Pressure Washer - DXPW3025
The pressure washer leaks from inside casing letting out water/soap might be affecting pressure of hose?
If your part of the country reaches freezing temperatures during winter, the pump probably froze. This can cause cracks to brass and (especially) aluminum pump heads. It is worth opening up the case; sometimes I find loose fittings (caused by freezing) which can be tightened up and everything is fine. If it is not freeze damage, the check valve may have gone out on the soap injector, causing pressure to back flow through the inlet barb. Otherwise, you may have a worn/leaking pump seal.
This is a consumer (throw-away) pressure washer. If it's not a loose fitting which can be tightened, the unit is probably not worth fixing.
Jul 01, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Pump runs but water keeps going out blow by will not build pressure
The seal inside the unloader has gone. It is normally an O ring and should be able to be replaced or get a new unloader.
Mar 12, 2014 | Dewalt Pressure Washer - DXPW3025
Checking warranty
how can we help you, what is the problem with it?
Oct 16, 2013 | Dewalt DXPW3025 3000 PSI Direct Drive...
No pressure
Any chance it froze during the past winter? They do need to be winterized.
May 04, 2010 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Dewalt 3700 pressure washer will not take in the cleaning solvents works fine but will not spray chemicals
Be sure that you have your chemical injector plumbed correctly. They will only work one way.
Oct 08, 2009 | Dewalt 3700 Pressure Washer
Garden Logo
154 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
