Question about Garland Ovens
I have garland convection oven using LPG gas , the temprerure adjestment controller and others buttons are not working on the controll board but display are coming so what is the reson..?
Its a double deck convection oven
reg501
  • 413 Answers
SOURCE: F1 error Dacor Oven
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Maytag in wall oven (part# MEW653ODDS).
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Posted on Nov 03, 2009
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Program board
Check with Lang regarding availability of a board
Aug 09, 2013 | Lang Manufacturing 1 Deck Electric...
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Why is the main 24 volt coil contactor chattering? I replaced the 3-pole contactor and thermostat but problem not solved.
chech the voltage going to the contactor if it is less then 21 volts i would change the transformer. sometimes the contactor will chatter because it is not getting enough voltage.
Nov 23, 2011 | Lang Manufacturing LGM-ECCOAP 1 Deck...
Ovens Logo
59 people viewed this question
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
