Question about Samsung DMT400RHS Builtin Dishwasher
Why does my dishwasher turn on but cant turn off with power button?
Heavy light flashes but cant turn machine off with power button. if hold power button, machine goes off but when release power button machine turns it self back on and heavy button flashes
2 Suggested Answers
ChildShield
  • 120 Answers
SOURCE: Samsung dishwasher flashing heavy light
Anytime a dishwasher stops mid cycle and blinks, it is usually because of clogged drain port, and safety switch prevents next cycle, so just blinks. You will probably see bottom of tub filled with water, and float switch is preventing next cycle which is calling for more water, and obviously there is not enough room, so shuts down next cycle. Remove as much water as you can with wet vac or turkey baster to suck out water, then try and see if cycle starts.
Remove bottom of tub filter, look for drain hole usually at back of tub and see if it is clogged, usually visible at top of drain. Pretty easy to fix, just clean out the area of food waste or broken piece from glass, another common sudden blockage. If you have wet vac, place it over drain hole and cup your hand around nozzle of vac and hole to creat seal and suction to insure clog isn't in drain hose.
Good luck, FREE-BUSINESSES.com
Posted on Nov 25, 2014
Normal, heavy, delicate lights stuck on--cant power on or off
If you have tried to unplug from mains power and there is no difference then you will need to provide the actual model number of your dishwasher in comments field.
The Samsung error codes for Normal, Heavy , Delicate lights stuck is not listed. The closest is Normal, Heavy, Quick which relates to a Low Water level. Also confirm which lights are stuck in your case and whether these are flashing or not.
Apr 17, 2014 | Samsung Dishwashers
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Maytag Dishwasher flashing lights
I have the same problem with the lights flashing on the control panel. It pops up every 4 or 5 months. The only solution I have found is to press the delay/resume button one time then press the drain/off button twice. You may have to hold the keys down for a couple of seconds. This seems to reset something in the panel. Make sure you haven't pressed the 3 second lock button or it won't work.
Mar 17, 2008 | Maytag MDB7100AWB Dishwasher
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
STUCK ON HEAVY WASH
First of all, if you've turned off the Correct power source it would stop running. Keep trying to find the correct circuit breaker. The power must be discontinued and let the dishwasher sit for at least 5 minutes so it can "forget" the program. However, if the same program comes back on, then I suggest holding down the heavy wash symbol continually for several seconds. Or perhaps holding down the cancel symbol for several seconds instead. It sounds like the heavywash symbol is stuck or broken behind it's cover. If the symbol was "jiggled" alittle to the right or left it may become "unstuck". Hope some of this helps you.
God Bless You and your family,
Miss Midget
Nov 02, 2007 | Asko 24 in. D3250 Built-in Dishwasher
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Samsung DMT400RHS Builtin Dishwasher Logo
126 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
