Question about Refrigerators
Water dispenser tube
Replace broken tube
  • Refrigerators Master
  • 5,323 Answers
SEE PIC
Water dispenser tube - water-dispenser-tube-kvax0h5nolktkyinzrohy2he-2-0.jpg
Posted on May 20, 2015
SOURCE: broken water dispenser in door
I was able to replace it without taking the door apart. There are clips on either side held in place with screws.
Posted on Nov 24, 2008
SOURCE: Water dispenser
The lever on the outside water dispenser is broken, how can this be fixed?
Posted on Apr 08, 2009
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
SOURCE: broken water dispensing tube
you h ave a project in front of you. you are going to have to remove the door entirely from the cabinet, including electrical and water line connections. you will then have to remove the inner door liner and gasket, to access behind the dispenser module. you will need to pull the line out from the bottom, carefully, and replace with new water line, then replace gasket and liner, and reattach door.
Good luck.
Posted on May 09, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Replace water inlet valve for
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Posted on Dec 17, 2010
Can you replace water dispenser tube inside door from front display panel or you need to disassembly door from inside fridge?
Unless the tube is cracked and broken, there should be no need to replace it. Try sending a small amount of compressed air through the tube to clear a suspected blockage.
Jun 17, 2015 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Broken water dispensing tube
Good luck.
May 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
My water dispenser wont give water ge #gsh25sgpc
possible frozen water supply tube behind fountain assembly, or broken tube at valve, bad valve, filter,filter mount assembly
Oct 23, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water in the bleach dispenser
The bleach dispenser is a syphon system. When you put in the bleach , it fills the reservoir to a point just below the syphon point. Your bleach tray has a tube attached to it, with a loose cap around the tube that causes the bleach to be delivered to the washload when the water is added. Remove the cap over the tube in your bleach tray. You'll also note a similar arrangement for your softener dispenser. Clean both caps and tubes. Make sure that the caps fit properly back down over the tubes. The syphoning effect will work only up to the point that the circuit is broken by air. If your cap sits up too high, the syphon effect is broken early, leaving residue (water) in the dispenser.
Best regards, --W/D--
Aug 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water dispenser spout broken
we had the same problem. My husband cut a flexible straw to the length he wanted, and crammed in in the hole. works great !! saved between $ 35.00 and $55.00 (labor was free)
Aug 06, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore 57033 Water Dispenser Broken
I had a similar problem on a frigidaire side by side. I think the water line may be freezing. My solution was to remove the filter inside the refridgerator and drain it and reinstall. This causes the water to flow into the filter and eliminates any ice in the tubing. I have not had the problem in a while. While not a true fix, it may help narrow it down.
Later on, I eventually replaced the microswitch on the door dispenser for an intermittent dispenser problem.
Hope this helps.
Dec 28, 2008 | Kenmore 57029 Side by Side Refrigerator
Water dripping from water dispenser tube.
Replace the dual solenoid valve which supplies water to the icemaker and the water dispenser. The solenoid that supplies water to the dispenser is not fully closing, therefore seeping water through the tube.
Apr 23, 2008 | Refrigerators
No water!!!
Your water valve has two seliniod valves. One for the ice maker and one for the drink dispenser. When you push the water dispenser lever, you should hear a small click. It is a micro switch inside the dispensing housing. The plastic frame may be broken that holds the switch. Your water tubing or water tank in the refrigerator may be frozen. A frozen water tank or tubing will not allow you to dispense water. If your water tank is frozen, you may need to replace your air diffuser(damper) if it happens again. It may be leakin cold air. I have these parts on Ebay as username, themackshack. Good luck!, Mack
Jan 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
