Question about Sewing Machines
Needle just falls out. Hemming some pants using the needle for Jeans/Denim 80/12. I can't even sew over a thick layer on these pants. I've never experienced anything like this. Help please?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
Steam the seam alot and pound it down with a hammer. This helps me.
Posted on May 08, 2015
  • 46 Answers
SOURCE: singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Posted on Oct 24, 2008
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
  • 10 Answers
SOURCE: STITCHES DEEP TO BOBBIN SIDE HAVE CHANGED
You do need an oiling and cleaning. Also, try adjusting on the bobbin cover by turning th little screw with a small screwdriver. Keep adjusting and testing until you get the loops just as you want them...
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: Loops on bobbin side
Typically loops are a tension problem. Have you tried resetting your tension? You may have to also adjust your bottom tension, but be sure you mark (with fingernail polish or a sharpie) the original position so that you can put it back if it doesn't solve the problem. Also, what type of needle are you using? Try a jeans needle, maybe a 90 or 100. And, what kind of bobbin thread are you using? If you're using the same jeans thread, it may be too heavy for the bobbin. Try regular cotton or poly in the bobbin.
Posted on Oct 01, 2009
SOURCE: sewing machine needle is stuck and the machine will not move.
you should go with the flow, just take a deep breath hayete w byemshe el hal
Posted on Nov 28, 2010
My brother started making a loud noise when sewing pant fabrics
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Jan 02, 2013 | Brother Sewing Machines
While hemming jeans with my Janome 7061NX (using a 100/16 sharp), it skips stitches at the thick seams.
try a denim needle
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 18, 2012 | Sewing Machines
What type of needle I need for our White Blue Jeans sewing machine Model 1577?
it depends on what type of fabric your using for the sewing project or even if it's to repair like a pair of pants like blue jeans you would want a denim needle
if you do not have a manual they have a free PDF download at singer .com---just follow these steps
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example w1577 ) & click search
Sep 20, 2011 | White Sewing Sewing Machines
I have been sewing denim, and the top thread keeps breaking at the needle. What adjustments do I need to make. It also bunches from the bobbin.
Are you trying to use a heavy thread like buttonhole twist through the needle like the yellow thread on store bought jeans? Most domestic machines will not cope with this heavy thread and it will be too large for the eye of the needle too.
If you are using regular weight 50 polyester thread and its breaking then it could be because the top tension is too tight. Just loosen off 1/2 a number on top tension dial and see if this helps.
If possible, buy a pack of jeans needles size 100 too, these are blue coated with teflon I think, and makes it easier to slip through denim which is a very dense fabric.
Hemming denim jeans is probably one of the toughest jobs for a domestic sewing machine so if you are trying to do this, its a good idea to take it slowly and use a "humpjumper" which helps to maneouvre over the thick side seams.
However, even with all the above, many machines won't sew more than one layer of heavy dense weave denim.
Jul 20, 2011 | New Home HF-106
My needle breaks 2 in a row
Don't pull your fabric as you seam as this is a sure fire way to break needles.
Also, make sure you have got the right foot on it for the stitch sequence it is sewing. For example, don't use a foot with a little hole in it when doing a zig zag as the needle will strike the foot. The general purpose clear plastic foot is usually a good one for most stitching.
If you are trying to sew something pretty heavy then this can cause breakages too as the machine may struggle to pierce through 6 layers of denim when you cross another seam. For example, hemming jeans, when you stitch over the side seams, your machine is trying to pierce probably 7 layers, the leg, plus the felled seam turned twice. It will struggle. You can help it by using a "Jeans-a-jig" a little plastic device you hold in front to get the foot up over the lump and give it grip. But take it really slow and sew one stitch at a time.
Jun 08, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I am having a terrible time sewing through several layers on trim on pockets that I attach to the front of tote bags. I sell these totes and need a polished, professional look. When I bought this...
try a
Jean-a-ma-jig or Hump-jumper
trying to sew over a bump of fabric, such as a thick jean hem, try using this tool
local fabric store should carry it
It keeps your pressure foot level as you sew over the
bump
you said your needle plate has many strike marks on it,,make sure you can't feel the strike marks so the fabric won't hang on them,,because marks on a needle plate can pulled the fabric
Sep 01, 2010 | Husqvarna Designer I
Bottom thread is loose and loopy
I would use a denim needle, these are blue coated to slide through the fibres, usually in size 100. But the looping is more about the weight of the seam, ie thickness. Also aremyou trying to use thick yellow jeans thread on the outside and normal thread inside? This is difficult to achieve as the thick yellow thread wont go through needle, you need to use it on the bobbin and sew right side down. I have never had much success with jeans hems on my Japanese machine and usually end up using my industrial Singer to do it. You can try usinf a seam jumper Sometimes called a jeans-a-ma-jig, this helps give leaverage to the feed dogs as you approach the side seams. Also, belt the seams flat with a hammer first.
Jan 18, 2010 | Elna Heirloom Edition 6005
Oct 01, 2009 | Singer Featherweight II 117
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
