Question about Ovens
Main oven is not heating. What is the fault and can I repair it myself?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Check that you have not accidently set the oven to auto mode on the timer this would cut the power to your oven.
Posted on Apr 27, 2015
Not heating up beeps continuously
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
May 23, 2012 | Smeg S1100MFX5 Electric Single Oven
Heating elements in fan oven not working
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Oct 27, 2011 | Ovens
Fan forced element is broken in my Smeg SA301X. I'd like to fix it by myself. I opened the cover in side and measured the element. there are 3 screws fixing element on the back wall. one in the bottom...
Aug 17, 2011 | Smeg SE250XUK Stainless Steel Electric...
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Hi main bottom oven will not heat, fan moves, light works but no heat. Is this something I can fix myself easily? Thanks Mrs edel Relph
You need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Dec 30, 2010 | AEG U3100-4 Electric Double Oven
Oven not heating up
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for candy element How to Repair Home Appliances
Jun 09, 2010 | Candy F248P Electric Single Oven
CREDA BUILT IN DOUBLE OVEN MIRROR FRONTS 2002 MAIN OVEN FRONT FAILED AT METAL TO GLASS HINGES IS THERE HEAT RESISTANT ADHESIVE OR WILL ARALDITE 150 C SERVE ?
Araldite will not do the job sati8sfactorily, as it it will not remain flexible as the oven gets hotter.
Go to the E-Bay site and look for high temp silicone adhesive for oven glass doors.
It is about£5.00 + p/p.
It is perfect the repair you need to do, I have used it myself, and recommend it.
Mar 27, 2010 | Creda Ovens
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
Top oven on uy46 working, bottom oven light coming on but no heat coming in??
If the fan is working o/k, then you need to replace the oven element, located behind cover at rear of oven compartment, very straightforward repair to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
