Question about Cameras
I need to troubleshoot a PDQ Laserwash 4000 - Cameras
  • Larry Mclain
    Larry Mclain Apr 26, 2015
    No it's not about a camera it is about a full automatic car washing system.I'm having a problem with the PLC, The drive is made by Mitsubishi Freqrol-Z024-UL. When I turn on the PLC,A error code displays on the front of the Mitsubishi driver it says error.There is a alarm indicator on the driver that is not lit. The error code will not let me in to clear or rest The error. Any suggestions would be grateful. Thank you for reading this have a good day!!
Put a 350 turbo transmission in a 1990 chevy k1500 pickup and need to change speedo to cable. What, where, how???
Local auto part stores have this part available, but possibly as a PDQ, or next day delivery to your local store.
Jan 07, 2014 | 1990 Chevrolet K1500
How do you turn on bluetooth on kyocera qualcomm 3g cdma phone?
    • 1 Turn on your Kyocera Qualcomm pdQ by pressing and holding the "Power" button until the welcome screen is displayed. If the keypad is open, press and hold the "Power" icon located on the right hand side of the phone's screen. Repeat the process to turn the phone off.
    • 2 Install the Palm Desktop Organizer software. Connect your phone's cradle to your computer and plug in the power cord. Remove your Kyocera Qualcomm pdQ from its cradle during installation. Exit any Windows programs on your computer. Put the Palm Desktop CD into your computer's CD-ROM drive. The installation screen will appear, click the "Install" button and follow the on-screen instructions.
    • 3 Perform your first information HotSync. Click the "Palm Desktop" icon on your computer's desktop. Click the "Sharing" button in the Windows taskbar to open the HotSync Manager, then click "Local." Turn on your phone and put it in its cradle. Open the Kyocera Qualcomm keypad, tap the "Sharing" button to open the HotSync menu and select "Local Sync." Enter your username on the computer and click "OK." When the sync is complete, a "Process Complete" message will display.
    • 4 Make a call with the keypad closed. Pull up the antenna on your Kyocera Qualcomm pdQ and wait for the signal strength icon to be displayed. Use the numeric keypad to enter the phone number. Press the "Send" button to make the call and the "End" button to hang up.
    • 5 Make a call from the call history on your Kyocera Qualcomm pdQ. Press the right "Smart Key" and use the "Up" and "Down" button to scroll through your call history until the desired number is highlighted. To see more information about the number, press the left "Smart Key." Press the "Send" button to make the call and the "End" button to hang up.
Feb 24, 2012 | Kyocera Cell Phones
The chain will not stay tight. After about i minute of cutting the chain gets loose and jumps off of the bar. I tighten everything really tight after adjusting the tension. It runs and cuts fine until...
On the aduster screw where you tighten blade ... is there an extra nut? I think you need to screw that nut tight so the adjuster screw cannot rotate from vibration.
Oct 08, 2010 | Homelite Garden
How to re boot verifone pdq vx 670
Simply unplug the line Cabletrace it to the other end and disconnect it
Jun 04, 2010 | VeriFone VX510
Blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Dec 28, 2008 | Dahlquist QX-4A Main / Stereo Speaker
Bassinet assemlby-Kolcraft
We have borrowed a Kolcraft bassinet but cannot figure out how to put the liner on it to completely assemble it.
Nov 10, 2008 | Kolcraft Easy Reach Ultra Light Vibes Crib
Cameras Logo
70 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
