Question about Nabi 2
It wont turn on when charging the red light is on for abut 4hours and then turns green i unplug it and it wont turn on ive holding down the volume + and power button and still nothing
What could be the problem anything at all would be very helpfull as it is my son tablet and he only got it 3 months ago.
    Sergeant:
  • 258 Answers
Tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Posted on Apr 26, 2015
    New Friend:
  • 21 Answers
Faulty battery
Testimonial: "what would i have to do get a new battery?"
I have the trio g5 10 and it gets stuck on the loading screen that says android and wont just wont turn off ....ive tried everything
Hi try holding down power button for approx 30 second's if this doesn't work hold Down power button & volume button at the same time & hope it reboots .cheers
Nov 04, 2017 | Tablets & eReaders
There is a red and green light on my irulu tablet when charging and wont turn on
Some tablet you have to hold the powe'd button for at least five seconds.If that don't work it's dead.
Jan 16, 2015 | Tablets & eReaders
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
My nabi tablet is charged but wont turn on
Try a different charger first, as it maybe faulty. If not the battery maybe faulty and I would purchase a new one.
Mar 16, 2014 | Nabi 2
My tablet comes on but has a green monster with a red triangle and it wont let my tablet get pass it
Hi.
There is corrupt data on the Proscan 7.
First of all if you have an SD card in the slot remove it and turn the Android on to see if it boots. If i does then you didn't have it inserted properly or its corrupt.
If is still shows a Android laying down then follow the procedure below.
1. IF YOUR TABLET IS ON, POWER IT OFF. 2. PRESS AND HOLD POWER UNTIL THE DEVICE POWERS ON, THEN IMMEDIATELY PRESS AND HOLD VOLUME DOWN (WHILE STILL PRESSING POWER). YOU WILL SEE THE WORD START WITH AN ARROW DRAWN AROUND IT.
3. PRESS VOLUME DOWN TWICE TO DESIGNATE RECOVERY MODE.
4. PRESS POWER TO RESTART INTO RECOVERY MODE. YOU WILL SEE AN IMAGE OF AN ANDROID ROBOT WITH A RED EXCLAMATION MARK.
5. WHILE HOLDING DOWN POWER, PRESS VOLUME UP.
6. USE THE VOLUME KEYS TO SCROLL TO "WIPE DATA/FACTORY RESET" AND PRESS POWER TO SELECT IT. 7. SCROLL DOWN TO "YES - ERASE ALL USER DATA" AND PRESS POWER TO SELECT IT.
Regards.
Jul 15, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
Nabi 2 Logo
300 people viewed this question
Top Nabi Tablets & eReaders Experts
Tom Bullen
Tom Bullen
Level 1 Expert
Steve
David Payne
David Payne
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
