Question about Hotpoint WMTL79 Top Load Washer
My machine won't empty
I have cleaned the filters and the machine spins but nothing comes out.i tried the house outlet at the front but not even a dribble comes out.Any ideas.
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Check pump i think its blocked
Posted on Apr 26, 2015
    New Friend:
  • 21 Answers
Blow through your outlet pipe and see if its blocked. and clear your water trap if it has 1
Testimonial: "Tried it even tried connecting an air bed foot pump but to no avail, trap all clean ....?"
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My washer is not working it begins to spin stops and has the letters LE appearing.
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
May 27, 2008 | LG Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
I have a stackable unit model numberltf2140fs2 it will not drain and go into spin cycle is there a strainer that needs cleaning how do iget to it
You need to locate and clean the filter. Unfortunately, on this model, it's in a horrible place!
Rather than try to describe it, if you go to the Sears Parts direct site and look at the diagram for the motor and tub at this web address:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/Model-LTF2140FS2/1428/0153200/R0906023/00003
You will see a diagram of the drum and associated parts. You can zoom in on the diagram. In the bottom right section of the diagram, you will see part number 41, the filter housing ad part number 40, the filter its self. You will need to:
Remove the clip (No. 48) that holds the housing to the empty pump
Remove the clip (also No.48) that holds the air chamber to the housing
Remove the clip (No. 42) that holds the housing to the drum
You should now be able to remove the filter housing and filter. Strip and clean it before reassembly.
If the above doesn't get you where you need to be, please come back to me with a comment and I will provide further assistance
Aug 15, 2011 | Frigidaire Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Frigidaire front load model ltf6000fso. does not go into the final spin. getting code e20. unscrewed the front panel from below. but do not know how to fully take the panel off so that i could see if...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
E20 error on Kenmore front loader. The water is
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Starts then stops and won't re-start
Plug off the wall first. Check your outlet filters, clean out. It is located right in front bottom right of machine. Push one side of the small door. The machine will not spin if the filter is blocked. Refit carefully. If you have manual, check for filter cleaning. While you are at it check your pump area too. Position machine switch to "off" position. Re-start........
Oct 14, 2007 | Frigidaire GLTF2940ES Front Load Washer
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Open Questions:
See all Hotpoint WMTL79 Top Load Washer Questions
Hotpoint WMTL79 Top Load Washer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
