Question about Microsoft Office Word 2013, English Version, Product Key
MSO137.acl Problem- please help!!! How can i overcome this?
Your AutoCorrect file, MSO137.acl, could not be saved. The file may be read-only, or you may not have permission to modify the file.
  • Microsoft Master
  • 2,045 Answers
Not enough information
Posted on Apr 26, 2015
Testimonial: "I try to open a file. and get this eror:Your AutoCorrect file, MSO137.acl, could not be saved. The file may be read-only, or you may not have permission to modify the file."
It says that "Your Auto
You can check out this link:
http://social.technet.microsoft.com/Forums/en-US/office2007deployment/thread/c1b0a32f-fbdf-42af-af7c-f0cccd798d5a/
or
-open RUN or search
-type "REGEDIT" on the run or search box
-navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
-Check if the Appdata value has a value, if not right click on the blank side choose New >> Expandable String Value then type "AppData" - without quotes
-right click on the value that was just created and choose Modify and type
"%USERPROFILE%\AppData\Roaming" - without quotes
Then restart..
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
Mar 24, 2011 | Computers & Internet
I saved my microsoft word file and when i opened it again it became an acl file which could not be opened on windows. Help ls.
I am not sure what has happened here. An .ACL file is a list of corrections used by the AutoCorrect feature in Microsoft Office; used for automatically correcting grammar and spelling mistakes. These AutoCorrect lists can be customised within Microsoft Office programs and are not meant to be edited manually.
I can only suggest you search again for the file to see if another copy has the correct .doc or .docx extension.
Mar 17, 2011 | Computers & Internet
When I type "=" character in Microsoft Word, nothing is typed. It's like the key is not there? Please help!
Please informe me your mention key " = " is working in other side? like notepad. If not then your key is damaged. You need to service the key . its a home made service. pull out the key & you must see the rubber pad is stucked inside & fixed. Use a pen try to fress on top, try to moving you will see the pad came back his own position. then you stick back your key & use.
Thanks & waiting for your feedback
Jan 31, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Autocorrect file (MSO2057.acl)
I would try a few things before reinstalling although reinstalling really is not such a difficult process. first try the detect and repair command or simply renaming the file as a RTF and seeing if you can close and reopen it under the rich text format. if so, then On the security tab, under "Group or user names", Administrators, SYSTEM and your Name (an administrator) are listed. The permissions for all of these names are; Full Control, Modify, Read & Execute, Read and Write
Jan 10, 2010 | RTO Franzis MS Office 2007 Home and...
How to convert word2007 files in to word2003
The office 2003 should prompt you to download a update to be able to read the files when you attempt to open one.
Here is the update/pack
http://www.microsoft.com/downloads/details.aspx?FamilyId=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Sep 01, 2009 | Microsoft Office Professional 2007 Full...
Auto Correct option is not working in all MS Office Versions
When you install Microsoft Office, AutoCorrect is set by default to try to match and correct a misspelled word with a word in the main dictionary that the spelling checker uses. However, if you want to make sure this option is enabled.
Do this is Microsoft Word:
  • Click the Microsoft Office Button
  • Click Proofing.
  • Click AutoCorrect Options
  • On the AutoCorrect tab, select the Automatically use suggestions from the spelling checker check box.
Jul 11, 2009 | Microsoft Office 2003 Basic Edition...
I WANT TO SAVE MY AUTOCORRECT OF OFFICE 2003 AS A BACK UP.
Start by locating your Outlook.NK? file at work, and putting it on a jump drive. Usually it is located in a folder like this:
C:\Documents and Settings\USER\Application Data\Microsoft\Outlook
That file contains settings you can transfer from one version of Office Outlook to another one. Generally, going forward, not backwards, like you want to do. But it is worth a try. Just for safety sake, back up all files in the destination location first, in case it does not work right. If it fails, at least you can bring things back from the backup, and restore your original settings.
Jun 04, 2009 | Microsoft Office Professional Edition 2003...
I have to disable ACL list created by administrator
Hello sir, disable simple file sharing to get access to the Security tab and ACLs. Hope this helps
May 06, 2009 | Computers & Internet
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Nov 26, 2007 | Computers & Internet
Microsoft Office Word 2013, English Version, Product Key Logo
117 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
