Question about Royal + 200 Mbps Digital Home Powerline Ethernet Adapters 1-port Bridge and 4-port Switch (RPL200C)
How do I connect? My royal+ rpl-200 can not connect with new operating system wndows7, yet worked with xp etc . thanks budlyte
  • 2,045 Answers
You need a new driver (for Win7) to get it functional. Refer to manufacturer site.
Posted on Apr 26, 2015
WHAT KIND OF SD CARD FOR A 1000 ML ROYAL ALPHA CASH REGISTER?
its the format of the card. format it to the right type I.e fat 32 etc etc
Sep 19, 2014 | Royal Alpha 1000ML 200 Department 5000...
Has anyone heard of an os called Windows 7 royale xp?
There is no Operating System called Windows 7 Royale XP but there is a Windows Theme for Windows 7 which is called Royale XP which will give you the look of how Windows XP was.
See http://www.askvg.com/download-windows-xp-royale-blue-theme-for-windows-7/ for more information.
Beware of any sites offering a free download of a Windows 7 Royale XP Super CD as this will probably not be what you might think and may well be malware.
Dec 05, 2011 | Dell Inspiron 1525 Laptop
Problem with royal+ powerline eathernet the one unit rpl-204 power light not on once i plug in few lights on after it is like dead any help thanks
You need to plug the unit with 1 port into an outlet near the source of internet connection and the second unit acts as the hub once plugged in.
Mar 06, 2011 | Royal + 200 Mbps Digital Home Powerline...
I need a new Windows Vista for my computer.I have got computer with Windows XP but I would like to have Windows Vista. What I have to do ?
First changing computer opering systems is possible. A new Vista operating system has to be acquire from retails usually $200 value pack. Attempting the install new operating systems is achievable only may require expert to ascertian whether the old would have to be deleted to make way for new. usually inserting the new disk into disk drive should capture new effects. Unless any peculair encounters were experieced, the installation change is achievale. The reason to allow technicain to perform the changes is to gurantee againts any situations that may occur least repairable by computer neophyte. estimate the program changes of $200 to acquire new system program and technicains experts installation may have raised costs. Installations of systems are usually same rates $49. Several options available to acquriing computers that has XP systems. Recent computers are windows 7. However, the used devices computer retails may have functioning computers with XP systems. Also, simple, acquire another computer system unit that performs on windows XP to be pluged into the monitor screen to attain experinces. Whenever required, the computer sytem unit with XP is interchaged with the computer with Windows Vista. Ironicly, i have a computer with Vista and would also need to convert to XP though experiecing cost conditions. Consider exchanging computers with me.
Feb 09, 2011 | Microsoft Windows Vista Ultimate Edition
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
OPERATING SYSTEMS INSTALL WITH THE HELP OF DHCP{RIS}
the easy copy your boot cd to server service pack sp2
  1. put this on a new drive. have your 200 systems do a restart boot to new root drive that will start auto install on all systems with root drive on server. you can set install options for quite in action needed. there are some texted files on help files windows xp install check it out you can set quite afew install options it select all options your installs and restarts all 200 systems at the same time. when you restart have server del of clients boot drive restart using normal server client root drives.
please that me know if this help you thanks
good luck
Mar 21, 2009 | Computers & Internet
USB Driver for Windows Vista
I am currently running Windows XP on my PC and upgraded it to a Windows Vista operation System does a USB driver exist for Windows Vista that will allow me to connect to my Panasonic KX-TDA 200 Phone System.
Jan 16, 2009 | Panasonic (KX-TDA200)
Weird error message on boot. BIOS error?
This is a strange one. Does the BIOS on your motherboard detect your hard drives at all? I'd try the lowest level first. If so, then try to boot from your XP CD ROM (hopefully this should work). Try to go into recovery console to see if your hard drive can even be mounted by the system. I'd check there.
If you still have issues,try to reflash your mobo BIOS to the most current one. Could be a flaky BIOS issue.
Feb 06, 2008 | AMI American Megatrends UltraSCSI...
Royal + 200 Mbps Digital Home Powerline Ethernet Adapters 1-port Bridge and 4-port Switch (RPL200C) Logo
448 people viewed this question
Top Royal Computers & Internet Experts
Jaime Hernandez
Phillip Whisenant
Phillip Whisenant
Vladimir Frolov
Are you a Royal Computer and Internet Expert? Answer questions, earn points and help others
